No LED for 5Ghz and 2.4Ghz on AP 215
  • 1.  No LED for 5Ghz and 2.4Ghz on AP 215
    Posted Dec 20, 2017 03:49 PM
    Hello, I have 2 access points AP 215 that the leds lights for 2.4 and 5Ghz stay off and theses AP are not working.  They are provisionned and I see them on the controller but it have nothing write under 2.4 Ghz Channel and 5Ghz Channel (see screen shots).  I tried factory_reset but same problem.
    Is anyone could help me?
    Here's the boot log:
    APBoot 1.5.3.9 (build 43867)
    Built: 2014-05-21 at 19:31:10
    Model: AP-21x
    CPU: P1010E, Version: 2.0, (0x80f90020)
    Core: E500, Version: 5.2, (0x80212152)
    Clock:
    CPU0: 800 MHz
    CCB: 400 MHz
    DDR: 400 MHz (800 MT/s data rate) (Asynchronous)
    LBC: unknown (LCRR[CLKDIV] = 0x00)
    L1: D-cache 32KB enabled
    I-cache 32KB enabled
    I2C: ready
    DRAM: Configuring DDR for 800 MT/s data rate
    DDR: 256 MB (DDR3, 32-bit, CL=6, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2: 256 KB enabled
    Power: 802.3at POE
    PCIe1: RC, link up, x1
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 14e4 4360 00002 03 80000004 00000000 00000000 00000000
    PCIe2: RC, link up, x1
    00 00 14e4 4360 00002 03 a0000004 00000000 00000000 00000000
    Net: eth0
    Radio: bcm43460#0, bcm43460#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xee000000
    Copying image from 0xee000000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [ 0.000000] Flash variant: variant0
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.5.4.1 (build 61494 / label #61494)
    [ 0.000000] Built by p4build@rhodes on 2017-09-18 at 19:25:47 PDT (gcc version 4.5.1)
    [ 0.000000]
    [ 0.000000] P1010 RDB board from Freescale Semiconductor
    [ 0.000000] Memory: 248728k/262144k available (10044k kernel code, 13416k reserved, 612k data, 376k bss, 6504k init)
    [ 0.001512] Brought up 1 CPUs
    [ 0.078132] PCI: Probing PCI hardware
    [ 0.121232] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [ 0.184131] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [ 0.246384] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [ 0.320878] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [ 4.939664] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [ 5.163444] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [ 5.238483] Amd/Fujitsu Extended Query Table at 0x0040
    [ 5.299981] number of CFI chips: 1
    [ 5.354395] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [ 5.436789] gfar_probe: Renaming interface to bond0
    [ 5.495601] /proc/gfar_bond0_stats created
    [ 5.595597] Enabling watchdog on CPU 0
    [ 5.642372] caam ffe30000.crypto: device ID = 0x0a14010000000000
    [ 5.714313] caam ffe30000.crypto: job queues = 4
    [ 5.769650] caam ffe30000.crypto: authenc-hmac-sha1-cbc-aes-caam
    [ 5.841656] caam ffe30000.crypto: authenc-hmac-sha256-cbc-aes-caam
    [ 5.915721] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des3_ede-caam
    [ 5.992936] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des3_ede-caam
    [ 6.072201] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des-caam
    [ 6.144182] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des-caam
    [ 6.223120] caam ffe30000.crypto: ccm-aes-caam
    [ 6.362041]
    [ 6.362046] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 6.453807] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 6.572695] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 6.644643] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 6.688439]
    [ 6.734308] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [ 6.829589] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [ 6.951559] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [ 7.074481] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [ 7.197389] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [ 7.332220] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
    [ 7.432590] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    AP-type has_ble_support: USB.
    Domain Name: arubanetworks.com
    No panic info available
    ardmore: Start hotplug
    Enabling ble_daemon via nanny
    [ 17.923478] AP xml model 84, num_radios 2 (jiffies 8790)
    [ 17.987073] apType 84 hw_opmode 0
    [ 18.026679] radio 0: band 1 ant 0 max_ssid 16
    [ 18.078783] radio 1: band 0 ant 0 max_ssid 16
    [ 18.137398] init_asap_mod: installation:0
    [ 18.563287] firewall cpu: core-0
    ardmore: Copying BT modules to /tmp
    Starting watchdog process...
    Getting an IP address...
    [ 22.846435] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ 28.855478] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    [ 28.929549] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    192.168.54.23 255.255.255.0 192.168.54.1
    Running ADP...Done. Master is 10.54.10.71
    [ 57.835128] wifi0: AP type AP-215, radio 0, max_bssids 16
    [ 58.051532] aruba_usb_power_control:1136 en:1 status:0
    [ 58.113098] aruba_enable_usb_block:556 Enabled USB
    [ 58.170415] aruba_usb_power_control:1141 Enable USB power control for 214/215
    [ 58.255858] tomatin_usb_power_control:975 enable the USB
    [ 58.617129] wifi1: AP type AP-215, radio 1, max_bssids 16
    03.00
    ardmore: Insmod BT modules
    [ 59.373088] usbcore: registered new interface driver usbfs
    [ 59.616875] usbcore: registered new interface driver hub
    [ 59.738098] usbcore: registered new device driver usb
    [ 59.899067] usbcore: registered new interface driver usbserial
    [ 60.189858] USB Serial support registered for generic
    [ 60.250585] usbcore: registered new interface driver usbserial_generic
    [ 60.328774] usbserial: USB Serial Driver core
    [ 60.471003] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 60.549213] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [ 60.628461] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [ 60.774708] fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
    [ 60.848925] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [ 60.915668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 60.996960] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 61.083442] usb usb1: Product: Freescale On-Chip EHCI Host Controller
    [ 61.160545] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    [ 61.225149] usb usb1: SerialNumber: fsl-ehci.0
    [ 61.336621] hub 1-0:1.0: USB hub found
    [ 61.381486] hub 1-0:1.0: 1 port detected
    [ 61.723568] usbcore: registered new interface driver cdc_acm
    [ 61.791360] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
    shutting down watchdog process (nanny will restart it)...
    <<<<< Welcome to the Access Point >>>>>
    Thanks!
  • 2.  RE: No LED for 5Ghz and 2.4Ghz on AP 215
    Posted Dec 20, 2017 06:22 PM
    Are the AP’s provisioned in a AP group with active SSID’s. If there is no SSID to broadcast a AP will not activate the radios.
  • 3.  RE: No LED for 5Ghz and 2.4Ghz on AP 215
    Posted Dec 20, 2017 08:25 PM
    Type "show ap details ap-name <name of ap>" and see the radio information.  You could have a hardware issue.
