No mesh-cluster-recovery profile is generated in Controller
  • 1.  No mesh-cluster-recovery profile is generated in Controller
    Posted Apr 05, 2016 03:31 AM
    Hi all,
    As per 6.4 UG, it mentioned that a mesh-cluster-recovery profile will be generated in master controller after meshing is configured and provisioned.
    But in the "show running config | include recovery" i don't see any output of it.
    Please help.
  • 2.  RE: No mesh-cluster-recovery profile is generated in Controller
  • 3.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Apr 05, 2016 06:54 AM
    Try this command:
    show ap mesh-recovery-profile
  • 4.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Apr 05, 2016 06:58 AM
    Got it.. thanks!
    the show running config | include recovery is misleading..haha
  • 5.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Apr 05, 2016 08:48 AM
    It was removed out of the running config around the 6.4 release, but Colin's command does expose it.
  • 6.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Oct 11, 2018 09:27 AM
    Waht about AOS8? I try to configure mesh on my VMC, but the GUI says 'No mesh recovery cluster profile.'
    In the CLI I see the same error:
    #show ap mesh-recovery-profile
    No AP Mesh Recovery profile is found
    What can be a problem here? Why VMC doesn't generate the recovery profile automatically? How can I enforce this?
    THX
    Cheers,
    LG
  • 7.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Oct 11, 2018 10:05 AM
    Do you have an MM in place?  According to the user guide here: https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Mesh/Mesh_Profiles_.htm?Highlight=mesh%20recovery it is generated dyamically by the MM.  That might not be available if you do not have an MM.
    I do see a mesh cluster profile on my MD and an MM is in place.
  • 8.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Oct 11, 2018 10:14 AM
    Hi Joseph!
    No unfortunately this is a standalone VMC, I have no MM installed.
    LG
  • 9.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Nov 07, 2018 09:18 PM
    rry for slow response. Standalone VMC to see mesh recovery profile is 'show ap mesh-recovery-profile'. it's not longer part of the running config.
    (ArubaMC-VA) [mynode] #show ap mesh-recovery-profile
    AP Mesh Recovery Profile
    Item            Value
    Cluster Name    RecoveryXOioKNstJd8a3Trl
    RF Band         a
    WPA Hexkey      ********
    WPA Passphrase  N/A
    Encryption      wpa2-psk-aes
  • 10.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Nov 08, 2018 03:21 AM
    Hi Jerrod
    The show ap mesh-recovery-profile command says:
    But this would be a quite strong limitation if a standalone controller wouldn't be able to provide mesh functionality....
    Cheers,
    LG
  • 11.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Nov 08, 2018 03:26 AM
    Meantime I installed another VMC - same standalone instance, same sw version - and there it seems the mesh recovery profile is there, so something went wrong on my controller, but it woudl be nice to have a commande which can enforce the regenartion of the recovery profile.
    Item Value
    Cluster Name RecoverypUgwAoAXwDH8Ll2X
    RF Band a
    WPA Hexkey ********
    WPA Passphrase N/A
  • 12.  RE: No mesh-cluster-recovery profile is generated in Controller
    Posted Nov 08, 2018 06:57 PM
    I don't know how it came up without a mesh recovery profile, that's generated on initial startup. A wr erase all should trigger it to rebuild, but if you still have it up and a wr erase all doesn't do it, open a TAC case so they can look at what's going on. If it was an early VMC from 8.0 and was upgraded over time, that might be it, but I don't know.
