No output on AP Console port
  • 1.  No output on AP Console port
    Posted May 06, 2015 06:06 AM
    Hi All,
    I've got some AP225s which I'm unable to get any output from the console port. FYI I am powering it on and have tested on a few different APs.
    If I unplug my serial cable from the AP and patch it into a controller I can get console access to the controller, so I know the cable works and the setting appear correct,
    Any ideas?
    Cheers
    James
    #AP225
  • 2.  RE: No output on AP Console port
    Posted May 06, 2015 06:08 AM
    Have also tried different USB to serial adapters..
    Here's the serial settings:
  • 3.  RE: No output on AP Console port
    Posted May 06, 2015 06:55 AM
    jrwhitehead,
    Those are correct parameters.
    Has the serial port on the AP225 ever worked for you in the past? What is the current adapter and what type cable are you using?
    #AP225
  • 4.  RE: No output on AP Console port
    Posted May 06, 2015 07:44 AM
    It has never worked with my current computer. (Surface Pro 3)
    It's a HL-340 USB to RS232 Serial Port Adapter with an Aruba serial to RJ45 connector and a cat5 cable.
    I've got;
    2 x usb to serial adapters
    2 x serial to RJ45 cables
    1 x serial to RJ45 connector
    lots of cat5 cables
    I've tested various combinations of the above to no avail. Also tested on another laptop and other APs.
  • 5.  RE: No output on AP Console port
    Posted May 06, 2015 08:40 AM
    Check your AP System Profile:
    (Aruba-Master) (config) #ap system-profile "default"
    (Aruba-Master) (AP system profile "default") #console-enable
  • 6.  RE: No output on AP Console port
    Posted May 06, 2015 08:48 AM
    The APs brand new and have never contacted the controller. They're on a VLAN with no DHCP and I need to configure 1 manually to test the solution.
  • 7.  RE: No output on AP Console port
    Posted May 06, 2015 08:57 AM
    JrWhitehead,
    You said you have never been able to bring up a console on AP225s, period, or is it just the new ones exhibiting the problem? It could be a hardware issue.
    #AP225
  • 8.  RE: No output on AP Console port
    Posted May 06, 2015 09:00 AM
    I've got an AP225 at home and I can't access the serial port on that. Also have 25 AP225s on an install I'm doing which I can't access the serial port on.
    All my serial cables work on controllers but not on the APs.
    #AP225
  • 9.  RE: No output on AP Console port
    Posted May 06, 2015 09:04 AM
    Are you using the same laptop?
  • 10.  RE: No output on AP Console port
    Posted May 06, 2015 09:07 AM
    No. I've tested with 2 different laptops.
  • 11.  RE: No output on AP Console port
    Posted May 06, 2015 09:39 AM
    I think we should open this up to anyone who has NOT been able to console into an AP225.
    #AP225
  • 12.  RE: No output on AP Console port
    Posted May 07, 2015 08:05 PM
    Jrwhitehead,
    I just checked with a product manager who exclusively uses a surface pro 3 and he regularly connects to the console of AP225s successfully.  You might want to RMA one of those access points to see if you have a bad batch.
    #AP225
  • 13.  RE: No output on AP Console port
    Posted May 14, 2015 07:18 AM
    I've got an AP225 at home in my lab which I'm getting the same result on. E.g. console access work to my lab 7010 controller but I get no output when moving the cable to the console port on my AP225.
    I've tested this with my personal laptop and get the same result.
    It would be a huge coincidence if my lab AP was from the same batch as the ones I've just installed for a customer.
    As nobody else has chipped in I'm assuming everyone else can access the console port on their AP-225-RW?
    Cheers
    James
  • 14.  RE: No output on AP Console port
    Posted Sep 22, 2016 12:58 AM
    Any updates on this issue.  I am having the same problem with Two AP225
  • 15.  RE: No output on AP Console port
    Posted Sep 22, 2016 05:03 AM
    You should open a TAC case, because this problem could be hardware specific or, you have your terminal configured wrong.
