no ssid-enable ; ssid-enable needed after change of PSK?
  • 1.  no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 26, 2015 03:46 AM
    We have a guest wlan, on which we change the WPA2 PSK every night. I use expect to do this, but this morning the ssid stopped working after changing the password. Clients' screen (android) just flickered a bit when trying to choose the guest-ssid. Forgetting the network and re-entering the PSK didn't help either.
    I found out that a 'no ssid-enable' followed by a 'ssid-enable' fixed that. Is this a documented feature, or was there something else that went wrong?
    7205 controller, iap-215 *30
    #7205
  • 2.  RE: no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 26, 2015 05:00 AM
    HI,
    It is not expected behaviour, SPK is no where related to SSID enable/Disable. you mentioned that you are using IAP 215, is it IAP deployment or Controllers based deployment ?
    Please clarify and try to replicate the issue.
  • 3.  RE: no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 26, 2015 05:14 AM
    The IAP's are converted to AP's. We actually have a mix of AP and IAP, but all are provisioned on the controller.
    I omitted the ssid-enable from my expect-script. Let's see if it works tomorrow or not.
  • 4.  RE: no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 27, 2015 02:55 AM
    Same thing happened this morning. My phone tried to connect to the guest-wlan, and I could tell that the screen flickered around the ssid in the Wi-fi listing (android).
    I ran a "no ssid-enable" and "ssid-enable". This immediatly made my phone connect, without any interaction.
  • 5.  RE: no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 27, 2015 07:07 AM
    HI,
    It seems we need to go through the entire configuration once to understand the issue hence I recommend you to open a TAC ticket and get it diagnosed.
  • 6.  RE: no ssid-enable ; ssid-enable needed after change of PSK?
    Posted Aug 27, 2015 07:19 AM
    I'm trying. Where can I submit a TAC-ticket on the TAC-ticket system :)
    The search-result field is just blue without any text. Cannot submit.
    (Went via View Case -> Enter new, ticket entered)
