I replaced several HP Procurve 2626 (J4900B) switches with HP Procurve 2620 (J9623A) switches.
I have the same VLANs and configuration in the switches with regards to IGMP etc, but WOL does not work any longer from one VLAN to another. If I stay in one VLAN, it works, but that is not what I am looking for.
I have used several firmware versions (RA.15.16.0005, RA.15.15.0008, RA.15.15.0008) but the result is the same.
Is this a missing feature on the 2620 or a configuration issue?
Kind regards,
Arjan
#ProCurve#Wake-on-LAN#2620#WOL
