Hey All,
So I have seen many posts where http://support.arubanetworks.com/ArubaOSKB/tabid/111/Default.aspx is referenced in which it is explained that increasing the wpa-key-time in the 802.1x config is a possible solution the clients responding to late etc... Soooo how would one address the situation if the users are NOT 802.1x users rather simply using WPA2-PSK?
rif
Thank you I will check to see if they are up to date. They are Motorola hand held scanning devices running some form of Windows. I shall post my results.
Thanks again,
