Anyone know what is the parameter to set to disconnect nortel/avaya switch users
What version of code? Only very recent versions of code on some Avaya switches support CoA.
! Model = Ethernet Routing Switch 4548GT-PWR! Software version = v5.7.1.021
it should support RFC 3576 IEEE 802.1X Security Extensions
Looks like you need to be on SW : v5.8.1.029 or greater for CoA support.
What type of authentication are you using? 802.1X or MAC-Auth?
currently testing on Mac-auth
Noted
