Network Management
not able to connect to airwave
  • 1.  not able to connect to airwave
    Posted Dec 13, 2013 12:48 PM
    hi
    i am not able to connect to airwave using https or http. the server is running and it is sending alert message. but i am not able to connect to the interface. any help on this will be appreciated.
    Karthik
  • 2.  RE: not able to connect to airwave
    Posted Dec 13, 2013 01:50 PM
    can you SSH as root to the server?  Issue the command "daemons" There should be a long list.  Try restarting them with the command "rd"
  • 3.  RE: not able to connect to airwave
    Posted Dec 13, 2013 01:54 PM
    Though restarting daemons is like hammering your way through the problem.  If you want to debug and find out the cause, it'd be worth opening a case with support.  Any crashes in the apache logs (/var/log/httpd/error_log or access_log)?
  • 4.  RE: not able to connect to airwave
    Posted Dec 13, 2013 02:13 PM
    [root@bhusd mercury]# daemons ?
      PID  PPID  PGID %CPU %MEM   RSS     ELAPSED CMD
     1751     1  1750  0.3  2.9 232644   20:06:52 VisualRF
     1464     1  1464  0.0  0.1 10912    20:08:11 Daemon::LowLevelServiceWatcher
     1521     1  1478  0.0  0.0   504    20:07:55 msgHandler
     1164     1  1164  0.0  0.0  1640    20:10:39 rrdcached
     1738     1  1738  0.0  2.9 230716   20:06:53 snmptrapd
    i dont see a long list just the above
  • 5.  RE: not able to connect to airwave
    Posted Dec 13, 2013 02:17 PM
    What is the output of # df -h
    i guess the server is out of disk space
  • 6.  RE: not able to connect to airwave
    Posted Dec 13, 2013 04:52 PM
    [root@bhusd mercury]# df -h
    Filesystem            Size  Used Avail Use% Mounted on
    /dev/mapper/VolGroup00-LogVol00
                           65G   14G   48G  23% /
    tmpfs                 3.8G     0  3.8G   0% /dev/shm
    /dev/sda1              97M   36M   57M  39% /boot
    have enough disk space
  • 7.  RE: not able to connect to airwave
    Posted Dec 13, 2013 04:56 PM
    Did you try 'restart daemons' ('rd' command) already?  If not, go ahead and do so and open a support case to see if they can help find the root cause.
  • 8.  RE: not able to connect to airwave
    Posted Dec 13, 2013 05:29 PM
    i did and below is the output
     and also i am able to connect to the interface .. thanks a lot for the help...and how do i enable autoboot...i restarted the server before running rd.. but the server is not doing autoboot. it stops in the boot prompt then i need to press enter to boot..please help me on this too.
     2218     1  2218  0.0  0.2 18716       02:08 airbus
     1924     1  1924 33.7 10.4 820716      03:18 httpd_
     2212     1  2212  1.1 10.3 815392      02:09 Daemon::ServiceWatcher
     2220     1  2220  0.0 10.3 814092      02:08 Daemon::PortGrabber
     2223     1  2223  0.0 10.3 814036      02:07 Daemon::TupleSpaces
     2226     1  2226  0.0 10.3 814092      02:07 Daemon::TupleScheduler
     2254     1  2254  0.0 10.3 814692      02:06 Daemon::SwarmHandler
     2272     1  2272  0.3 10.3 814984      02:04 Daemon::PerfCollector
     2276     1  2276  0.0 10.3 813776      02:04 Daemon::AlertD
     2283     1  2283  0.9 10.3 815404      02:03 Daemon::APListCacher
     2286     1  2286  0.0 10.3 814520      02:03 Daemon::APScanner
     2289     1  2289  0.0 10.3 813872      02:03 Daemon::APWatcher
     2293     1  2293  0.0 10.3 814044      02:02 Daemon::APWatcherPollNow
     2296     1  2296  0.0 10.3 814580      02:02 Daemon::AsyncLoggerClient
     2299     1  2299  0.0 10.3 813784      02:01 Daemon::ConfigPusher
     2306     1  2306  0.0 10.3 814048      02:01 Daemon::ConfigVerifier
     2310     1  2310  0.0 10.3 814512      02:00 Daemon::DeviceEvent
     2317     1  2317  0.0 10.3 814072      02:00 Daemon::DNSFetcher
     2333     1  2333  0.0 10.3 814020      01:59 Daemon::PartialConfigPusher
     2336     1  2336  0.0 10.4 818936      01:59 Daemon::PAPI
     2339  2336  2336  0.0 10.3 814464      01:59 Daemon::AMONAggregator
     2375     1  2375  0.0 10.3 813812      01:54 Daemon::SNMPEnabler
     2378     1  2378  0.0 10.3 814076      01:54 Daemon::SNMPFetcher
     2384     1  2384  0.0 10.3 814952      01:14 Daemon::SNMPV2Fetcher
     2387     1  2387  0.0 10.3 814952      01:14 Daemon::SNMPV2Fetcher
     2390     1  2390  0.3 10.4 817704      01:14 Daemon::SyncD
     2397     1  2397  0.0 10.3 813812      01:13 Daemon::WepKeySetter
     2437     1  2437  0.0 10.3 815408      01:11 Daemon::AsyncLoggerClient
     2395  2394  2394 25.7  2.1 169708      01:13 VisualRF
     2200     1  2200  0.3  0.1 10268       02:12 Daemon::LowLevelServiceWatcher
     2257     1  2212  0.0  0.0   504       02:06 msgHandler
     2266     1  2266  0.0  0.0   900       02:04 pound
     2268  2266  2266  0.1  0.0  4332       02:04 pound
     2366     1  2366  0.0  1.0 85668       01:54 radiusd
     1115     1  1115  0.0  0.0  1196       06:30 rrdcached
     2382     1  2382  0.0  2.9 230600      01:14 snmptrapd
  • 9.  RE: not able to connect to airwave
    It would seem that none of the other daemons are currently running on your server.  Check to see if the disk drive of the AMP is full:
    # df -h
    If it's not, then doing the 'rd' that Seth suggested could possibly get you back up and running.  But the fact that apache/pound are not visible explains why the UI was unreachable.  There may be better clues to the outtage in /var/log/low_level_service_watcher or service_watcher logs.
