Running firmware 16.05.0004 on a JL259A
sw# config
sw(config)# ip multicast-routing
Invalid input: multicast-routing
What am I doing wrong?
Greetings!
The command should be present in the global configuration context; when you type 'ip' and then a question mark to show possible config parameters, what do you see?
Thank you.
It turns out my switch was running from the secondary image (older firmware)
Everything is running OK after forcing the swicth to boot from the primary image (16.05.0004)
Thanks again.
