Not able to login to 650-us controller
  • 1.  Not able to login to 650-us controller
    Posted Jan 16, 2020 01:45 AM
    i ordered a 650-us off ebay and not able to use the web GUI
  • 2.  RE: Not able to login to 650-us controller
    Posted Jan 16, 2020 03:40 AM
    How are you trying to access the WebUI?
    Could it be that there is configuration on the controller which makes the factory default IP is not reachable?
    Do you have access to the serial console port to see the actual configuration and test connectivity?
  • 3.  RE: Not able to login to 650-us controller
    Posted Jan 16, 2020 04:16 AM
    I can login by serial adn feset to factory defaults with the ecteption of the ip config
    System name: CurlHomeWiFi
    Switch Role: master
    VLAN 1 interface IP address: 192.168.1.60
    VLAN 1 interface subnet mask: 255.255.255.0
    IP Default gateway: 192.168.1.1
    Time Zone: PST-8:0
    Ports shutdown: no
    I am using chrome to access the web GUI by entering 192.168.1.60 I can login but I just get a gray screen
  • 4.  RE: Not able to login to 650-us controller
    Posted Jan 16, 2020 04:26 AM
    I think to remember that there has been an issue some years ago where browser updates broke the WebUI.
    What firmware are you running?
    Can you upgrade to the latest supported for the 650 (I think that is version 6.4.4.22)?
    Can you try different browsers or older versions of them to see if that makes a difference?
  • 5.  RE: Not able to login to 650-us controller
    Posted Jan 16, 2020 04:33 AM
    I have used firefox and the same thing
    IP Address Name Location Type Version Status Configuration State Config Sync Time (sec) Config ID
    192.168.1.60 CurlHomeWiFi Building1.floor1 master 6.1.2.7_31856 up UPDATE SUCCESSFUL 0 2
    Im not sure how to update the firmware via the CLI
    I purchaced this learn how to configure an aruba net work sence i had so many extra AP's
  • 6.  RE: Not able to login to 650-us controller
    MVP
    Posted Jan 16, 2020 06:05 AM
    That is  easy to to as long as you have ip connectivity.
    Set up a tftp server (eg. https://tftpd32.jounin.net/) and point it to the directory where you have the new firmware downloaded.
    Then from CLI check what partition is currently used:
    show image version
    Then just use the copy command to copy the firmware file to, preferably, the other partition.
    (Aruba7005b) #copy tftp: 1.1.1.1 ArubaOS_6xx_6.4.4.22_72860 system: partition ?
    0                       Partition 0
    1                       Partition 1
    <cr>
    (Aruba7005b) #copy tftp: 1.1.1.1 ArubaOS_6xx_6.4.4.22_72860 system: partition 1
    When that is done the controller will tell you to reboot. Reboot and voila.. you should be done.
  • 7.  RE: Not able to login to 650-us controller
    Posted Jan 16, 2020 11:26 AM
    probem solved you will need a the updated firmware though
