Not able to send Radius CoA or disconnect message from Clear Pass.
  • 1.  Not able to send Radius CoA or disconnect message from Clear Pass.
    Posted Mar 25, 2015 11:31 PM
    I am testing a solution with Clearpass with Juniper EX switches.
    I am not able to generate Radius CoA or Disconnect message. When I explore Access Tracker and click on change status I see Radius CoA option disabled and I can't enable it.
    If anybody has working solution or configuration steps; please share.
    Regards
    -Rajeev
  • 2.  RE: Not able to send Radius CoA or disconnect message from Clear Pass.
    Posted Mar 25, 2015 11:35 PM
    Do you have CoA enabled in the NAD configuration?
  • 3.  RE: Not able to send Radius CoA or disconnect message from Clear Pass.
    Posted Apr 02, 2015 06:26 PM
    Please update us with your problem.
    I had the same problem and it was revealed to be that the Juniper EX2200C-poe needed a software upgrade.
