Not possible to block youtube traffic from youtube app in Instant
  • 1.  Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 11:55 AM
    Hi guys,
    I am trying to block youtube traffic on my Instant AP. I was able to block youtube traffic just selecting youtube from the services drop down menu, although this only works for youtube traffic from www.youtube.com.
    When I open my youtube app I can see videos as always. I have added two more rules, streaming from application-category and streaming-media from web-category, but I can still see videos from the youtube app.
    Is there anyway to block traffic from this app? I am running InstantOS 6.4.4.8-4.2.4.3_56707. Many thanks in advance.
    Julián
  • 2.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 01:28 PM
    That worked for me, youtube app will simply not play the videos.
    I have not tried it on that version of firmware you mentioned though.
    I suggest opening a tac case
  • 3.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 02:00 PM
    Hi Pasquale,
    Did you try with the three rules simultaneously or just with youtube from services?
    What InstantOS version did you try on?
    Julián
  • 4.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 02:38 PM
    it was a while back to be honest and I believe i was in the 4.2.1 code train..
    I do not recall enabling the other two but i cannot be sure.
    I can attempt to re-test when i find some time.
  • 5.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 03:32 PM
    Hi Pasquale,
    Ok, if you find some time I will appreciate you re-test. Many thanks.
    Julián
  • 6.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 04:14 PM
    Hi Julián,
    I was able to test using an IAP-103 with standard software release version: ArubaInstant_Pegasus_6.4.4.8-4.2.4.6_58505
    The behavior on a laptop is the video will not play (website loads)
    The behavior on a smartphone with the Youtube app is like you described, the videos play.
    My ACL on my IAP looks as follows:
    all dhcp to all
    deny application youtubeeducation to all
    deny application youtube to all
    allow all
    If I add deny streaming to all above both youtube ACLs, it still allows me to stream youtube from the APP.
    I suggest you open a TAC case.
  • 7.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted May 31, 2017 04:55 PM
    Hi Pasquale,
    Many thanks for you interest. I will open a TAC case then.
    Julián
  • 8.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted Nov 10, 2017 02:59 PM
    Buenas tardes.
    Tengo el mismo problema, como lo resolvieron
  • 9.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted Nov 10, 2017 03:03 PM
    Guillermo,
    I suggest you to upgrade to the last InstantOS version. If the problem persists then you might open a TAC case.
    Julián
  • 10.  RE: Not possible to block youtube traffic from youtube app in Instant
    Posted Nov 12, 2018 06:48 AM
    Try this to Block all Youtube options
