Thanks! I hadn't realized I wanted this until I saw your post.
Installed.
Matthew Sabin
Original Message:
Sent: Aug 31, 2017 12:22 PM
Subject: Notepad++ user language with keywords highlight for Aruba cfg files
Hi all!
I share with you an easy solution for read and edit ours aruba controller's files with the famous Notepad++ editor.
In this way you don't need install any addicional software, you only need to import the language file to Notepadd and use it.
This user-define language helps you to read the configuration files by marking the keywords that usually are important. Also you can add your own keywords to language.
Screenshot
Here you can download de last Aruba-user-define-language:
https://sourceforge.net/projects/notepad-aruba-cfg-highlight/files/
HOW TO IMPORT THE NEW LANGUAGE TO NOTEPAD++
- Download the last .xml file from the before link.
- In Notepad++ select Language -> Define your language -> Import
- Select the .xml file that you downloaded.
- In the 'User language' list, select the new language. In "Ext" box, type 'cfg' if you want Notepad++ select automatically the new language with cfg's files.
- Reload the notepad++ application.
