Notification of guest accounts due to expire in X days?
  • 1.  Notification of guest accounts due to expire in X days?
    Posted Aug 20, 2018 07:39 AM
     Hi
    A customer have long term subcontractors connecting to the guest network with guest accounts with 6 month validity time.
    Is there any built in feature to send a notification to the subcontractor and sponsor in advance to the expire date?
    The function should be similar to the notice sent when a certificate in Onboard is due to expire.
    The only solution I can think of is to do this with API, but my request is if there are any other ways to achieve the same.
  • 2.  RE: Notification of guest accounts due to expire in X days?
    Posted Aug 20, 2018 08:01 AM
    You coudl try "Expiration Warning Options" under ClearPass Guest >> Configuration >> Guest Manager.
  • 3.  RE: Notification of guest accounts due to expire in X days?
    Posted Aug 20, 2018 08:22 AM
    Thank you for the information.
    This would solve half the issue, but not send a request to the sponsor to extend the account.
  • 4.  RE: Notification of guest accounts due to expire in X days?
    Posted Aug 20, 2018 08:47 AM
    You could enable Send Copies and try calling the sponsor_email as below.
    Send Copies: => Always send using 'cc:'
    Copies To: => {$sponsor_email}
    Note: I have not tested this before. But, give it a try.
    You can go with API if the above doesn't work for you.
  • 5.  RE: Notification of guest accounts due to expire in X days?
    Posted Sep 18, 2019 12:40 AM
    Hi, has anyone worked out how to CC the sponsor?  I have tried {$sponsor_email} and _admin with no luck?
  • 6.  RE: Notification of guest accounts due to expire in X days?
    Posted Sep 18, 2019 02:59 AM
    I believe this is a different Q hence it would be best to open a new thread.
