NPS and AD CS on the same server
  • 1.  NPS and AD CS on the same server
    Posted Feb 15, 2012 11:39 AM
    We are in the process of installing a certificate authority in our domain in order to issue machines certs, however we were wondering what were the best practices for installing one.
    Would it cause a security issue to have the AD Certification Services on the same server as the NPS?
  • 2.  RE: NPS and AD CS on the same server
    Posted Feb 15, 2012 12:31 PM
    @Yann wrote:
    That would be fine.
  • 3.  RE: NPS and AD CS on the same server
    Posted Feb 20, 2012 05:10 AM
    It is generally considered best practise to have the CA server offline and detached from the network unless it is supposed to sign certificates. However in a small enviroment that might be expensive och otherwise impossible. Using the NPS server as a CA is no problem, I've seen several organisations using that approach and it has worked perfectly.
