Network Management
NPS Configuration for Airwave Management Access
  • 1.  NPS Configuration for Airwave Management Access
    Posted Jun 15, 2017 01:19 PM
    Hello all...  The only point I am lost on is the Vendor Specific Attributes.  Neither Aruba or HP are in the dropdown list, so I don't know what to choose, and I don't know the syntax for the Attributes to configure.  Any assistance offered would be greatly appreciated.
  • 2.  RE: NPS Configuration for Airwave Management Access
    Posted Jun 16, 2017 03:40 AM
    Please check https://community.arubanetworks.com/t5/Security/Microsoft-NPS-custom-attributes/m-p/96029/highlight/true#M3309 to learn how you can add the Vendor Specific Attributes to NPS.
    There is a table of the ID numbers that you need for each attribute as well; you only need to add the attributes that you will actually use.
  • 3.  RE: NPS Configuration for Airwave Management Access
    Posted Jun 16, 2017 07:04 AM
    You need to return the Aruba-Admin-Role.  In the example below I am returning read-only.
    That is using PAP also.  I am seeing issues with PEAP-MSCHAPv2.  Hope that helps.
