Developer
  • 1.  NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted May 21, 2020 12:17 PM
    Cheers
    Customer has asked me to demonstrate that our AOS-CX switches can replace a legacy switching solution that has NQA functionality configured to decide which of the two routes (active - standby) should route traffic. Important to note, Customer does not use dynamic routing protocols.
    Reading the AOS-CX monitoring and NAE guides I concluded the same functionality that NQA delivers can be achieved by combining the functionality of IP-SLA with a NAE script (conectivity_monitor v1.1).
    The way to demo to Customer was this way:
    1. Virtual test environment setup using the AOS-CX OVA (Virtual.10.03.0020). Picture1.png
    3. Configuration of Agents and setup of the monitoring dashboard: Picture3.png
    The result of the demo was successful, combining IP-SLA and NAE I was able to demonstrate a routing policy based on the availability of the main - backup links.
    4. Syslogs collected: Picture4.png
    This is the video of the PoC result. Attached you will find a pdf with all the details.
    (view in My Videos)
    Adolfo
    Attachment(s)
    pdf
    IPSLA CX.pdf   5.59 MB 1 version
  • 2.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted Jun 11, 2025 09:10 AM
    Solution for CX6200 and CX6300 switches ??
    Hello this is exactly what I need (dual ISP failover) but does anyone have a NAE script (or a suitable solution) that works on a Aruba CX 6200 and CX 6300??
    Neither of those switches will upload the 'connectivity_monitor' script and I can't figure out what commands are causing the issue.
    Or if anyone has solved this another way ?
    Many thanks
    Peter
  • 3.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 11 days ago
    Hi, I need the same solution for CX6200, did you get the NAE script for CX6200/6300?
    Thanks!
  • 4.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 11 days ago
    Not yet but .....!!! Aruba/HPE Tech support are investigating it for me.
    I have an open ticket with them and they advised that they tried to test the script but could not even get it to load on an 83xx Switch so ....
    I'm keeping my fingers crossed they might yet come up with a solution ... or something :)
  • 5.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 11 days ago
    Thanks for your response! Hopefully they will get it working for cx 6300/6200 as well :)
    Nart.
  • 6.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 11 days ago
    Edited by willembargeman 11 days ago
    I checked but couldn't find the script for the 6200/6300 series. However, there are additional capabilities with the NAE lite scripts. Did you have a look into this? The documentation include an example that tracks the status of IP-SLA
    https://arubanetworking.hpe.com/techdocs/AOS-CX/10.15/HTML/nae/Content/Chp_NAE_lite/nae-lit.htm
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 7.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 4 days ago
    Do you have look / ask https://github.com/aruba/nae-scripts/ ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 8.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 4 days ago
    Yes I have been all over GitHub looking for a solution but no luck :(
    GitHub is where I got the original none working script.
    FYI I have an open ticket with  HPE/ Aruba support and they are investigating it for me.
    Thanks for the reply though :)
    Sent from my iPhone
    The email you received and any files transmitted with it are confidential, may be covered by legal and/or professional privilege and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this in error, please notify us immediately. If you are not the intended recipient of the email or the person responsible for delivering it to them, you may not copy it, forward it or otherwise use it for any purpose or disclose its contents to any other person. To do so may be unlawful. Any views or opinions presented in this email are solely those of the author and do not necessarily represent those of Nexus Associates (ICT) Ltd. Nexus Associates (ICT) Ltd. is not responsible for any changes made to the message after it has been sent.
  • 9.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 4 days ago
    You can ask on Github issue...
  • 10.  RE: NQA on AOS-CX? IP-SLA plus NAE script is the answer
    Posted 3 days ago
    Thanks.... Good idea..
    I have asked the question on Github as well.
    Cheers
    Peter Killoran
    peter.killoran@nexus-associates.co.uk
    M: 07595 081957 | T: 0208 418 2686
    W: www.nexus-associates.co.uk
    A picture containing text, font, screenshot, graphicsDescription automatically generated
    Advance notice:
