Thanks for the reply.
No, there is no NTP server configured.
For the Aruba OS, I'm running 6.4.3.4 and I'm using Chrome browser; so probably that' should be the reason.
By the way, do you knwo what is the last stable Aruba OS version I can use for the CTRL?
