HI Please find the output,
Distribution1(config)# show time
Wed Dec 8 05:12:23 2021
Distribution1(config)# show ntp status
NTP Status Information
NTP Status : Enabled NTP Mode : Unicast
Synchronization Status : Not Synced Peer Dispersion : 0.00000 sec
Stratum Number : 16 Leap Direction : 0
Reference Assoc ID : 0 Clock Offset : 0.00000 sec
Reference ID : 0.0.0.0 Root Delay : 0.00000 sec
Precision : 2**-18 Root Dispersion : 0.01705 sec
NTP Up Time : 0d 0h 18m Time Resolution : 420 nsec
Drift : 0.00000 sec/sec
System Time : Wed Dec 8 05:12:30 2021
Reference Time : Mon Jan 1 05:30:00 1990
chandan kp
Original Message:
Sent: Dec 07, 2021 02:58 AM
Subject: NTP IN 3810M
Hello Chandan, can you show us the output of show time and show ntp status executed one after the other?
Something like:
SW# show time
Tue Dec 7 08:54:08 2021
SW# show ntp status
Synchronization Status : Synchronized Peer Dispersion : 0.00000 sec
Stratum Number : 3 Leap Direction : 0
Reference Assoc ID : 0 Clock Offset : 0.28818 sec
Reference ID : x.y.w.z Root Delay : 0.02923 sec
Precision : 2**-18 Root Dispersion : 0.98162 sec
NTP Up Time : 297d 14h 2m Time Resolution : 419 nsec
Drift : 0.00051 sec/sec
System Time : Tue Dec 7 08:54:13 2021
Reference Time : Tue Dec 7 05:21:29 2021
Davide Poletto
Original Message:
Sent: Dec 07, 2021 02:27 AM
Hi
I configured ntp in Aruba switch the ntp status is Synchronized but not showing correct time?
chandan kp
Original Message:
Sent: Dec 07, 2021 02:17 AM
Hello chandan.kp,
What is the problem you are facing with NTP? Following is the guide for setting it up you may use NTP and SNTP starting from page 24:
Document - 16.10 Aruba 3810 / 5400R Management and Configuration Guide for ArubaOS-Switch 16.10 | HPE Support
Hope this helps!
-Alex
Original Message:
Sent: Dec 07, 2021 12:53 AM
Any one done NTP
chandan kp
