Wired Intelligent Edge
NTP on cx8100 and vsx
  • 1.  NTP on cx8100 and vsx
    Posted 22 days ago
    i have a CX8100 cluster with VSX. I use ntp server on the cluster and vsx-sync. The time difference between the two members ist sometimes more than 500ms.
    Since we use active-gateway the time on the gateway has a lot of jumps and is not stable.
    My config:
    ntp server 10.9.48.14 minpoll 4 maxpoll 4 iburst prefer
    ntp enable
    ntp conductor vrf default stratum 3
    Time difference on a ntp poller show more than 500 ms:
    Member 1:
    20:04:14, d:+00.0004406s o:-00.5095729s
    20:04:16, d:+00.0003544s o:-00.5095596s
    Member 2:
    20:04:11, d:+00.0003458s o:-00.0031110s
    20:04:13, d:+00.0003545s o:-00.0030572s
    Cluster address active-gateway shows the jumps:
    20:05:20, d:+00.0004535s o:-00.0026952s
    20:05:22, d:+00.0003394s o:-00.4556304s
    20:05:24, d:+00.0004084s o:-00.0027029s
    Any idea how to fix the time on the active-gateway address?
    Thanks in advance
    Florian
  • 2.  RE: NTP on cx8100 and vsx
    Posted 16 days ago
    It seems as the clock on CX8100 is not very precise or doesn't sync very well with your upstream time server.
    You may try the following:
    • instead of sync'ing both CX with an external server, sync only one of it with the external server and sync the VSX secondary node with the VSX primary. Perhaps this will have the effect of a less big gap between the two clocks
    • I think it's not a good idea to sync other devices with the two CXs by using the active-gateway address. Because you have two independent (but synchronized) clocks, you should use both "real" IPs instead of one "virtual" IP representing both the clocks.
    Let us know your results, please.
    Thomas
