Comware
  • 1.  NTP on HP Switch 5412Rzl2
    Posted Oct 01, 2020 03:08 PM
    1) I have a local NTP server, 2 core switches and a bunch of access switches. NTP server is on vlan 50. I pointed one core switch to the local NTP server, it is working fine.
    2) Management VLAN is, say, 70.
    3) I want 1 more core switche to be peer to the 1st core switch and the access switches to point to the 2 core switches and be stratum 4.
    # 1 is working fine, how should i proceed with #3? I tried just pointing other switches to the core switch - they don't receive any info. Should i setup an ACL or would the exchange happen on the Management vlan? I don't see the appropriate "peer" commands on the switch either. Please advise.
    #stratum
    #5412
    #NTP
  • 2.  RE: NTP on HP Switch 5412Rzl2
    Posted Oct 02, 2020 08:53 PM
    Hi @Olala1389 , the Switch can act as a NTP Server for other peers: it can only act as a NTP Client pointing to other NTP Server(s). Giveng that your scenario can't be deployed the way you want. Generally it's a good practice to configure each switch to point to one ore more NTP servers locally reacheable, why you can't do that on your network?
