Wired Intelligent Edge
NTP server problem
  • 1.  NTP server problem
    Posted Aug 04, 2016 06:11 AM
    Hi all,
    I am trying to launch Controller setup wizard. I don't use NTP server for time synchronization, just want to keep local time [see pictures 1 NTP].
    But at the end of setup I have an error [see picture 2 error] that 'Cannot delete the NTP server', but NTP server has never been installed at all.
    What You will suggest me to do?
  • 2.  RE: NTP server problem
    Posted Aug 05, 2016 05:56 AM
    I would either restart the wizard or put a dummy NTP server in (0.pool.ntp.org is a good one, that you can even use if you have internet access).
    After the wizard finishes, you can change/delete NTP again if you like under Configuration -> Management -> Clock.
