Wired Intelligent Edge
NTP Setup Aruba CX
This thread has been viewed 26 times
  • 1.  NTP Setup Aruba CX
    Posted Apr 22, 2022 04:56 PM
    This has been working on our HP Procurve, but did have to rebuild the NTP, so not sure what I'm missing.
    We are using a Windows server as an NTP source and found a thread about setting AnnouceFlags to 4, but so far that is NOT working.
    As for the switch:
    I have NTP enabled
    No Auth
    default VRF
    Not synchronized with an NTP Server is the message I get.
    6100 series
    Windows Server 2022
    Shane Farmer
  • 2.  RE: NTP Setup Aruba CX
    Posted Apr 22, 2022 06:40 PM
    On Aruba-CX the ntp commands are pretty simple:
    ntp server {ntp_server} iburst
    ntp enable
    ntp conductor vrf default stratum 3
    6300-cx# show ntp conductor
    NTP Conductor Status : Enabled
    VRF Stratum
    default 3
    6300-cx# show ntp status
    NTP Status Information
    NTP : Enabled
    NTP Authentication : Disabled
    NTP Server Connections : Using the default VRF
    System time : Fri Apr 22 22:35:54 UTC 2022
    NTP uptime : 5 days, 6 hours, 7 minutes, 20 seconds
    NTP Synchronization Information
    NTP Server : 132.246.11.229 at stratum 2
    Poll interval : 1024 seconds
    Time accuracy : Within -0.000303 seconds
    Reference time : Fri Apr 22 2022 22:31:52.989 as per UTC timezone
    Can you ping the ntp source?
    Have you confirmed that there is no port blocking between the devices?
    Shieva Eccles
  • 3.  RE: NTP Setup Aruba CX
    MVP EXPERT
    Posted Apr 25, 2022 05:58 PM
    TOP# config
    TOP(config)# clock timezone europe/amsterdam
    TOP(config)# ntp server x.x.x.x iburst
    TOP(config)# ntp enable
    TOP(config)# write mem
    TOP(config)# show ntp status
    TOP(config)# ntp server 172.16.200.1 iburst
    Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 4.  RE: NTP Setup Aruba CX
    Posted Apr 26, 2022 03:13 AM
    I have seen a problem with NTP on CX failing intermittently and we have worked round it by using IP addresses for the servers rather than DNS names.  We do not suspect anything to be wrong with our DNS, but NTP repeatedly failed to synchronise until we referred to the servers by IP.  You don't show your config but this may work for you?
    David Rickard
