NTP source address
  • 1.  NTP source address
    Posted Oct 28, 2015 09:26 AM
    Hey!
    the WIFI controller sits in the DMZ and got one leg in the MZ. The controller IP is one of the MZ range. But now I want to use a NTP server in the DMZ. As far as I understand the controller uses its controller ip for the NTP lookup in the DMZ. This cant work.
    Now I cannot change the source interface of the NTP client on the controller, correct? My idea is to use a NAT rule, but maybe there is a nicer way to do what I want?
      remote                                  local                                    st   poll   reach    delay     offset      disp
    =192.168.0.1                            8.8.8.8                              16 1024       0    0.00000     0.000000    3.99217
  • 2.  RE: NTP source address
    Posted Oct 28, 2015 09:57 AM
    They way you are thinking of doing it , is the best way .
    Unfortunately you can;t change the source IP address it will use the address defined here : "show controller-ip"
  • 3.  RE: NTP source address
    Posted Oct 28, 2015 10:21 AM
    Hmm in a production enviroment... :-) Just to make sure, is that correct what I'm planning?
    I make a net pool just for the ip of my DMZ Interface
    ip nat pool NATPool_DMZ2 192.168.0.5 192.168.0.5
    Then I create a policy
    ip access-list session "SNAT_NTP-access"
    alias "controller" host 192.168.120.2 "svc-ntp" src-nat pool "NATPool_DMZ2" position 1 queue low
    any any any permit position 2 queue low
    But I also need to allow all other traffic coming from and going to the controller, like it was before. Correct?
    alias "controller" host 192.168.120.2 "svc-ntp" src-nat pool "DREGER_NATPool_DMZ2" position 1 queue low
    Until here I'm already unsure, but now I have to assign this rule to a port. But what do I choose?
    interface gigabitethernet 1/8
          ip access-group "SNAT_NTP-access" session vlan 120
    Thanks for your help.
    Greets
  • 4.  RE: NTP source address
    Posted Oct 28, 2015 04:01 PM
    I recommend you do this during a maintenance window .
    The last part the only thing I would remove is this
    Everything else looks good.
