Network Management
  • 1.  NTPD Errors
    Posted Apr 19, 2017 04:41 PM
    Im getting a lot of these errors on 1 of my controllers.
    ntpd[28529]: Invalid-NAK error at 100630
    However after a search, i cant seem to find out what it means.
  • 2.  RE: NTPD Errors
    Posted Apr 19, 2017 07:04 PM
    Do you have an NTP server configured on your controller?  What is the configuration?
  • 3.  RE: NTPD Errors
    Posted Apr 20, 2017 07:11 AM
    #show ntp status
    Authentication:         enabled
    time since restart:     223808
    time since reset:       223808
    packets received:       483
    packets processed:      0
    current version:        446
    previous version:       2
    declined:               0
    access denied:          24
    bad length or format:   0
    bad authentication:     0
    rate exceeded:          0
    system peer:          0.0.0.0
    system peer mode:     unspec
    leap indicator:       11
    stratum:              16
    precision:            -19
    root distance:        0.00000 s
    root dispersion:      3.35712 s
    reference ID:         [73.78.73.84]
    reference time:       00000000.00000000  Thu, Feb  7 2036  1:28:16.000
    system flags:         auth monitor ntp kernel stats
    jitter:               0.000000 s
    stability:            0.000 ppm
    broadcastdelay:       -0.049988 s
    authdelay:            0.000000 s
     #show ntp servers
    NTP Server Table Entries
    Flags:     * Selected for synchronization
               + Included in the final selection set
               # Selected for synchronization but distance exceeds maximum
               - Discarded by the clustering algorithmn
               = mode is client
      remote                                  local                                    st   poll   reach    delay     offset      disp
    =xxx.xxx.xxx.41                           xxx.xx.xxx.20                            16 1024       0    0.00000     0.000000    3.99217
  • 4.  RE: NTPD Errors
    Posted Apr 20, 2017 07:47 AM
    access denied:          24
    Choose another NTP server
  • 5.  RE: NTPD Errors
    Posted Apr 20, 2017 07:49 AM
    I totally missed that. Thanks Joseph!
  • 6.  RE: NTPD Errors
    MVP EXPERT
    Posted Apr 20, 2017 07:50 AM
    Can you confirm the NTP servers are reachable from the controller and correctly responding to NTP requests.
    In the "st" column, if you have the value of "16" then this means NTP is not updating correctly. Also note that offset and disp are not returning values either.
  • 7.  RE: NTPD Errors
    Posted Apr 20, 2017 08:37 AM
    Turns out the authkey was wrong somehow.
    Thanks for the help!
