number of AP a controller a support
  • 1.  number of AP a controller a support
    Posted Mar 01, 2013 06:36 PM
    i have 3200 controller and it can support 32 AP. It is reaching the maximum AP that the controller can support. I notice that it can also 8 unit of wired access point. What does wired access point mean? can i use it to extend the number of AP the controller can support?
    #3200
  • 2.  RE: number of AP a controller a support
    Posted Mar 01, 2013 08:23 PM
    Good night
    :smileyhappy:
    The WiredAP aint help you get what u asking for.:smileysurprised:
    The WiredAP usually used to connect Aruba switch's (2500/3500) and allow them to get AAA/access roles/vlans from the main Aruba controller.
    In order to controller more AP units you should consider:
    • Buy another small controller (use it as local)
    • convert your deployment from CAP to RAP (GRE to IPSEC) (GRE=up to 32 IPSEC=up to 128) - just add more pef/ap lic's
    • buy Instant AP units (use them as Virtualcontroller manged -  connected VPN ipsec to your controller)
    Hope it gave you some ideas on how to extand you deployent .
    :smileywink:
    have a lovely weekend.
    Me
