Hi Pavan.
Not sure about termination of Access Points. They should be configured to load balance on controllers and so should the clients.
I see around 603 client on the MM-VA. There is 296 on the first controller and 287 on the second controller Airwave reports 297 Clients. All 3 controllers and all AP’s are added to Airwave and reports “UP” and configuration “GOOD”.
However, when I look at the “Client Count” the MM-VA reports 0 and the two 7205 are showing clients.
The “prefer AMON” was not enabled. I just turned it on. After 5-10 minutes, it looks like it is correct
Thank you for the help.
Kind regards.
NM
