Number of devices a guest user has registered
  • 1.  Number of devices a guest user has registered
    Posted Jan 19, 2018 08:32 AM
    Where do i find the devices a user has register. We limit our guets user to 3 devices, which i can see, but a user is having problems accessing the network and i want to see how many devices that user has registered and what they are.
    Where would i find that in Clearpass?
  • 2.  RE: Number of devices a guest user has registered
    Posted Jan 19, 2018 09:08 AM
    If you been adding the Guest email / user to the endpoint db
    You can do a search under Configuration >Identity > Endpoints DB
    Select Attribute from the filter drop down and then pick username , this will allow you to search for all the mac addresses tied to a particular username/email
  • 3.  RE: Number of devices a guest user has registered
    Posted Jan 19, 2018 09:25 AM
    While i have a big list of MAC address, I dont have usernames nor a dropdown for it.
    When i check the Guest policy, the it uses the Endpoints Repository
  • 4.  RE: Number of devices a guest user has registered
    Posted Jan 19, 2018 09:43 AM
    Are you doing mac caching ?
  • 5.  RE: Number of devices a guest user has registered
    Posted Jan 19, 2018 10:04 AM
    Yes, Sorry.
    MAC Caching,
  • 6.  RE: Number of devices a guest user has registered
    Posted Jan 19, 2018 10:09 AM
    You can add the following to the mac caching post_auth enforcement profile when the user performs the web authentication
    This way you will be able to see the device mac associated with guest username/email in the endpoint db
    Note: The only Attribute you need to add is the Endpoint : Username : % {Authentication:Full-Username}
  • 7.  RE: Number of devices a guest user has registered
    MVP
    Posted Jan 23, 2018 08:55 AM
    For ease of troubleshooting I put that unique-device-count in a seperate condition and attach a role (Device Count Exceeded) to it.
    This way in Access Tracker I can see right away if this is a cause for connectivity issues. Much easier than having to search the endpoint repository every time.
