Hi all, I had a configuration problem where the AP175 cannot connect to the aruba-master.
I followed the procedure noted in "http://community.arubanetworks.com/t5/Aruba-Instant/How-do-I-reset-IAP-175-to-factory-settings/td-p/48296"
I can get to the apboot> prompt but then the AP cannot accept/display the factory_reset command or any other command that I have issued at the prompt. I've tried different machines, cables, terminal programs but no joy?
Can anyone help with this problem?
