Odd issue after updating the certificate on conductor
  • 1.  Odd issue after updating the certificate on conductor
    Posted 15 days ago
    This morning I've updated the certificate on our conductors / controllers and when I run show crypto-local pki serverCert I get the output
    Certificates
    Name            Original Filename  Reference Count  Expired
    AOS23NEW        AOS23NEW.p12       0                No
    AOSwild24       aos2024.p12        3                No
    This is what I would expect. Similarly, when I run show web-server profile I get the output
    Web Server Configuration
    Parameter                                          Value
    Switch Certificate                                 AOSwild24
    Captive Portal Certificate                         AOSwild24
    IDP Certificate                                    AOSwild24
    All good so far.
    When I run the command no crypto-local pki servercert AOS23NEW, I am told:
    [mm] (config) #no crypto-local pki serverCert AOS23NEW
    Cert 'AOS23NEW' in use by 3 ref
    Very confused as to why this may be the case! Has anyone else seen this?
  • 2.  RE: Odd issue after updating the certificate on conductor
    Posted 15 days ago
    Double check that configuration is in sync with no failures for all devices.  I've seen odd behaviors before where the order of operations ends up in a bad state.  Fix required adding the certificate back with the same names to overwrite and then carefully removing everything one step at a time.
    Carson Hulcher, ACEX#110
  • 3.  RE: Odd issue after updating the certificate on conductor
    Posted 11 days ago
    Annoyingly, everything was fine. In the end, before re-applying the certificate I did the old "switch it off and on again" routine (my usual first line fix) and it fixed the issue.
    Thanks for getting back to me! :-)
