Odd issue after updating the certificate on conductor
  • 1.  Odd issue after updating the certificate on conductor
    Posted Jun 14, 2024 07:39 AM
    This morning I've updated the certificate on our conductors / controllers and when I run show crypto-local pki serverCert I get the output
    Certificates
    Name            Original Filename  Reference Count  Expired
    AOS23NEW        AOS23NEW.p12       0                No
    AOSwild24       aos2024.p12        3                No
    This is what I would expect. Similarly, when I run show web-server profile I get the output
    Web Server Configuration
    Parameter                                          Value
    Switch Certificate                                 AOSwild24
    Captive Portal Certificate                         AOSwild24
    IDP Certificate                                    AOSwild24
    All good so far.
    When I run the command no crypto-local pki servercert AOS23NEW, I am told:
    [mm] (config) #no crypto-local pki serverCert AOS23NEW
    Cert 'AOS23NEW' in use by 3 ref
    Very confused as to why this may be the case! Has anyone else seen this?
  • 2.  RE: Odd issue after updating the certificate on conductor
    Posted Jun 14, 2024 02:29 PM
    Double check that configuration is in sync with no failures for all devices.  I've seen odd behaviors before where the order of operations ends up in a bad state.  Fix required adding the certificate back with the same names to overwrite and then carefully removing everything one step at a time.
    Carson Hulcher, ACEX#110
  • 3.  RE: Odd issue after updating the certificate on conductor
    Posted 27 days ago
    Annoyingly, everything was fine. In the end, before re-applying the certificate I did the old "switch it off and on again" routine (my usual first line fix) and it fixed the issue.
    Thanks for getting back to me! :-)
