Comware
  • 1.  OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Sep 22, 2020 11:15 PM
    Have 3x OfficeConnect 1950 (48 port PoE & non-PoE models) currently stacked via 10GbE Base-T using ports 51 & 52 on each switch.
    I want to free up these 10GbE ports and use the SFP+ ports (49 & 50) instead.
    My concern is that re-configuring the stack ports, i may overwrite some config on one of the switches... wondering what the best way to do this would be and whether or not there are any special considerations or caveats i should look for?
    Bonus question:
    If i also wanted to add a 4th 1950 switch to the stack, what's the best way to do this? Keeping in mind, this 4th switch already has a working config that i need to keep when adding to the stack...
    Any advice or help would be much appreciated, thanks!
    #OfficeConnect1950
    #stack
    #HPE
    #OfficeConnect
  • 2.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Sep 23, 2020 03:07 AM
    Is this switch follows comware command line?
    Kindly share product number 'JXXXXX' of the switch.
    Thanks!
  • 3.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Sep 23, 2020 05:53 AM
    yes it does!
  • 4.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Sep 23, 2020 05:57 AM
    You can and a 4th switch similarily as in here:
    https://www.youtube.com/watch?v=-IcmyQXtvlw&list=LL9PcdKiwO-U4BwhMBIFJ0hg&index=27&t=369s
    Check out this series of videos, they are super helpful!
    Unfortunately I have requested the 6th video (referenced in the 5th video) in the series but I never received a response in the Youtube channel.
    Maybe HP people reading here can pull the srings to help to publishing it?
  • 5.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Sep 23, 2020 08:19 AM
    You can refer my post into below link:
    This is a similar kind of requirement and but its for HPE 5800 switch. but IRF concept reamins same.
    https://community.hpe.com/t5/comware-based/hp-5800-irf-configuration/m-p/7094730#M12872
    Thanks!
  • 6.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Oct 01, 2020 07:32 AM
    @akg7 wrote:
    Thanks!  Telldunkin
    Wow, it’s very helpful blog for comments. Will try to follow all these stuff!
  • 7.  RE: OfficeConnect 1950 - Existing Stack, change from 10GbE to 10Gb DAC
    Posted Oct 12, 2020 11:58 AM
    Has my post helped you to answer your query?
    Thanks!
