Hi all, anyone know the size of the log file on an old 6000 controller ? I take it when full it just overwrites ?
Each individual log has a 90k buffer. There are three buffers for each and yes they overwrite.
Cheers Colin, sorry to be dim but what logs are there exactly ? and can the size be adjusted ?
Ta
The size cannot be adjusted. You need to use syslog if you want to keep as many logs as possible.
Configuration> Management> Logging will show you what logs are available and where you can enter a syslog server.
