last person joined: 2 hours ago
  • 1.  Ommit
    Posted Sep 14, 2017 11:05 AM
    I have a single line in my config to send user severity notification logging to a syslog server
    logging 10.250.248.8 type user severity notifications
    in addition to the <NOTI> messages, I am also receiving lots of <ERRS> messages.
    My question is...Can I allow the notification messages but block the <ERRS> messages to my logging server 10.250.248.8 ?
    Randy
  • 2.  RE: Ommit
    Posted Sep 15, 2017 04:33 AM
    Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/logging_level.htm?Highlight=severity
    Usage Guidelines
    There are eight logging severity levels, each with its associated types of messages. Each level also includes the levels below it. For example, if you set the logging level to informational (6), all messages from level 0 through level 5 (from emergencies through notifications) are also logged. The warnings severity level is set by default for all message categories.
  • 3.  RE: Ommit
    Posted Sep 15, 2017 10:26 AM
    Colin...thanks for the response...always appreciate your thorough responses.  Is there any chance the higher level messages can be suppressed...my FW team is complaining about the events per second hit they are getting from  the 0-4 level logging...Thanks again...Randy
  • 4.  RE: Ommit
    Posted Sep 15, 2017 06:46 PM
    Randy,
    There is no solution on the Aruba Side.  Informational can be quite chatty and should really only be used during debugging.  What are you looking for?
