On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
  • 1.  On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 08, 2014 05:42 PM
    I have not yet deployed an IAP-275, but we are installing one for a customer.  In the installation guide, it states that "The WAN port supports 802.3at Power over Ethernet (PoE), accepting 48 VDC (nominal) as a standard defined Powered Device (PD) from a Power Sourcing Equipment (PSE) such as a PoE midspan injector."  Does this mean that ONLY the WAN port will accept POE+ and, therefore, I should plug the ethernet cable from my switch into the WAN port instead of the LAN port?
  • 2.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 08, 2014 05:43 PM
    Eth0
  • 3.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 08, 2014 05:50 PM
    Thanks for the speedy response. Is Eth0 labeled as such on the IAP-275? Our installers are currently mounting the hardware, so I don't physically have it to look at.
  • 4.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 08, 2014 06:24 PM
    Here's a photo of the one on my lab-bench right now:
  • 5.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 08, 2014 06:30 PM
    Outstanding. I could not find a good picture to reference. The installation doc only says "WAN" and "LAN". Many thanks to you and cappalli.
  • 6.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 15, 2014 09:08 AM
    Hi Guys Does anyone know where I can get the installation guide for the iAP275? Thanks Mike
  • 7.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
  • 8.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Aug 15, 2014 09:19 AM
    Thanks!
  • 9.  RE: On an IAP-275, which ethernet port (WAN or LAN) do I connect to my switch to use POE for power?
    Posted Dec 12, 2017 04:10 AM
    If I connect WAN port to a switch with PoE,
    Can i connect LAN port to any IP Camera (to power up the IP Camera) and transfer data from IP camera passing through 275 to the switch.
