Onboard + Android 11 up & certificate validation
This thread has been viewed 44 times
  • 1.  Onboard + Android 11 up & certificate validation
    Posted Nov 03, 2021 09:11 AM
    Hi all,
    I'm trying to deploy Onboard to circumvent the new requirement for Android (11 up versions) devices in regards to certificate validation.  This devices are employee's own and will be connecting to an internal corp SSID (not Guest).
    Question - the ClearPass csr does it have to be sign by a pub CA or it can be internal? I'm thinking it has to be public since Android devices will not trust our internal cert.  I would like some validation before moving forward.
    Also, I'm curios what are you folks doing in regards to this?
    Cheers,
    MG
    Mauricio Guzman
  • 2.  RE: Onboard + Android 11 up & certificate validation
    Posted Nov 03, 2021 10:36 AM
    Your EAP server certificate should always be issued from a PKI your organization controls.
    Tim C
  • 3.  RE: Onboard + Android 11 up & certificate validation
    Posted Nov 04, 2021 06:19 AM
    In addition to the advice to use an internal CA for the RADIUS EAP certificate, you should use EAP-TLS with client certificates and use some kind of provisioning toolings like an MDM or ClearPass Onboard to get your root CA pushed to the clients, and get the clients securely configured.
    Starting with Android 11, Google is enforcing secure connections (which is good) and that requires the certificates to be in place, and that is unfortunately not so simple to do. But at least it prevents end-users from configuring 'Do not validate certificate' and create an insecure setup.
  • 4.  RE: Onboard + Android 11 up & certificate validation
    Posted Feb 15, 2022 09:31 AM
    Hi Herman, this is great information, I have watched few of your videos also. Little confused about the Onboard. If I have Android 11+ and I am using Clearpass onboard, I will still have to initially go through accepting the private certificate. How will that work? Wouldn't I run into the same issue?
    Mohammad Ali
  • 5.  RE: Onboard + Android 11 up & certificate validation
    Posted Jul 09, 2024 09:23 PM
    Hi Mohammad, did you ever get this working?
