Onboard cannot autojoin
  • 1.  Onboard cannot autojoin
    Posted Nov 04, 2014 05:56 AM
    Hi   everyone
         I  have question about onboard
     When i connect to onboard SSID(Single SSID) and after onboarding  and device get wireless Profile (EAP-TLS)  but device cannot  autojoin  to onboard SSID
    I must manually connect SSID  to work
    how to solving problem
    Thank you
    regards
  • 2.  RE: Onboard cannot autojoin
  • 3.  RE: Onboard cannot autojoin
    Posted Nov 04, 2014 09:47 PM
    IOS and MAC OSX devices will not automatically connect to a new SSID. It is a know Apple issue and that is what you will need to put a notification at the end of the onboarding for those users that they will need to manually connect to the New SSID. If it is same SSID onboarding then yes it will automatically connect with the link that Victor provided.
    There is no issues with Windows and Android to change to the new SSID, only Apple.
  • 4.  RE: Onboard cannot autojoin
    Posted Nov 07, 2014 01:42 AM
    Thank you very for your kind support
    regards
    OYEA!
