Onboard CPPM as intermediate - what template to sign csr
  • 1.  Onboard CPPM as intermediate - what template to sign csr
    Posted Aug 08, 2014 11:40 AM
    I'm trying to setup Clearpass for onboarding as an Intermediate CA.  Have generated the CSR, but wondering what sort of template needs to sign this from a Microsoft CA?
    The error I'm getting is 'Certificate is not a CA'.
  • 2.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Aug 31, 2014 07:43 PM
    Me too, ClearPass 6.3.
    I have tried with both User and Web Server templates, but same error "Certificate is not a CA"
  • 3.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Sep 01, 2014 12:26 AM
    You need to make sure the account you use to log into the cert srv page has the correct rights. You need to reqest a sub ca.
    Here is what it should look like if you have the full admin rights.
  • 4.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Sep 01, 2014 03:32 AM
    Just to add a few thoughts in addition to what tarnold said.
    Make sure the user you are requesting the certificate with have the Enroll security access on the template.
    • MMC CA console -> Certificate Templates -> Right-click Sub CA Template / Properties / Security. Verify that the user you are logged in with have Enroll properties
    • If OK - try to run the browser with Run as command to get the Domain Admin access, unless you have the rights on your user
    Make sure the template is actually Published.
    • MMC CA console -> <name-of-ca-server> -> Certificate Templates
    • Is it listed here? If not - Expand <name-of-CA> and right-click the Certificate Templates folder -> choose New / Certificate Template to Issue. Select the Subordinate CA template and click OK
  • 5.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Sep 02, 2014 04:00 PM
    Kudos both tarnold and jsolb. Good solution and advise
  • 6.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Oct 13, 2014 07:20 AM
    ok, finally got back round to having a go at this, and having some probs.
    Customer has signed the request with the subordinate template.
    So I click on 'Install certificate'
    And then try to import it, but it just gives this error.
  • 7.  RE: Onboard CPPM as intermediate - what template to sign csr
    Posted Oct 13, 2014 07:47 AM
    ok, the original CSR was generated many weeks ago and seems there is a timeout.
    I deleted the CA and then started again, and then the import worked fine.  :-)
