Onboard Deployment Options
  • 1.  Onboard Deployment Options
    Posted Oct 17, 2018 10:46 AM
    Hi community,
    In ClearPass we have two options for Onboarding:
    • Single-SSID Onboarding: user connects their personal devices to the secure 802.1X SSID to do the onboarding, then connect back to the same SSID after onboarding.
    • Dual-SSID Onboarding: user connects their personal device to some provisioning SSID, typically an open SSID like a guest SSID. Next, they go through the onboarding process, and after onboarding, connect to the secure SSID using EAP-TLS.
    We are going to use Onboard in my customer and we are interested on the single-SSID onboarding option, but I don't know if it will be possible for some reason. I mean, what do I have to consider to see if single-SSID is possible or otherwise I need to use dual-SSID?
    Many thanks,
    Julián
  • 2.  RE: Onboard Deployment Options
    Posted Oct 17, 2018 10:48 AM
    Only dual SSID onboarding should ever be used. Using single puts users’ credentials at risk during the Onboard process.
    Simply put a link on the bottom of your guest portal.
  • 3.  RE: Onboard Deployment Options
    Posted Oct 17, 2018 10:54 AM
    Hi Tim,
    Why single-SSID puts users’ credentials at risk during the Onboard process? In my customer people which is going to onboard the devices are corporate users.
    Julián
  • 4.  RE: Onboard Deployment Options
    Posted Oct 17, 2018 10:56 AM
    You’re using legacy, known vulnerable protocols to initially connect. This should never be done.
  • 5.  RE: Onboard Deployment Options
    Posted Oct 17, 2018 10:59 AM
    Ah ok, I understand. Taking into account that, is there anything else which restricts the single-SSID option for onboarding?
    Julián
  • 6.  RE: Onboard Deployment Options
    Posted Oct 17, 2018 11:03 AM
    Nothing else can be taken into account since you should never use single. Please, don’t do it.
