Onboard Device Limits by Group
  • 1.  Onboard Device Limits by Group
    Posted Jun 09, 2013 01:05 PM
    In ClearPass 6.1 with OnBoard, what is the proper way to enforce different maximum onboarded devices limits by user group?  Should this be done using unique provisioning settings pages with the Max Devices option or through role mappings in the Onboard Authorization service?  If the latter, is it just a matter of sending something in the enforcement profile (Aruba-Mdps-Max-Devices?) or is there more configuration involved?
    Thanks!
  • 2.  RE: Onboard Device Limits by Group
    Posted Jun 09, 2013 08:21 PM
    The latter and there is no more configuration needed after sending the attribute.
  • 3.  RE: Onboard Device Limits by Group
    Posted Jun 09, 2013 08:47 PM
    Thanks Colin,
    For iOS devices (which do two authorization checks), should this attribute be returned in both or just the second authorization check?
    Will this result in users receiving a message indicating that their device allowance has been reached?
  • 4.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 01:17 AM
    The first one is all that is needed.
  • 5.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 11:29 AM
    So I have setup two services, one which handles the Pre-Auth request from the web GUI and also returns the Aruba-Mdps-Max-Devices, and a second service which handles the second auth request and just returns a radius accept for users in certain roles. I have Aruba-Mdps-Max-Devices set to 1. So far, I have onboarded three devices using the same account. Access tracker shows the roles are being assigned properly and the radius response from the Pre-Auth request includes Aruba-Mdps-Max-Devices 1. Any ideas why this is happening?
    Request Details Summary -
     Session Identifier: R00000045-03-51b5ece7
     Date and Time: Jun 10, 2013 11:12:39 EDT
     Username: onboardt2
     End-Host Identifier: 00:23:12:55:a0:5f
     Access Device IP/Port: 127.0.0.1:0
     Audit Posture Status: UNKNOWN (100)
     System Posture Status: UNKNOWN (100)
     Login Status: ACCEPT
    Policies Used -
     Service: GPS-Onboard-PreAuth
     Authentication Method: PAP
     Authentication Source: AD:dc.ssav.com
     Authorization Source: GP-AD
     Roles: Onboard-1-Device, [User Authenticated]
     Enforcement Profiles: Onboard - Limit 1 Device
     Service Monitor Mode: Disabled
    Input RADIUS Attributes -
     Radius:Aruba:Aruba-Essid-Name = GP-OBSecure
     Radius:Aruba:Aruba-Port-Id = device_provisioning
     Radius:IETF:Calling-Station-Id = 00:23:12:55:a0:5f
     Radius:IETF:Connect-Info = 10.90.10.3
     Radius:IETF:Event-Timestamp = 4450374-05-02 01:00:23
     Radius:IETF:Framed-IP-Address = 10.90.10.3
     Radius:IETF:Login-IP-Host = 10.90.0.90
     Radius:IETF:NAS-Identifier = cppm.ssav.com
     Radius:IETF:NAS-IP-Address = 127.0.0.1
     Radius:IETF:NAS-Port = 0
     Radius:IETF:NAS-Port-Type = 15
     Radius:IETF:Service-Type = 17
     Radius:IETF:User-Name = onboardt2
    Input Computed Attributes -
     Authentication:ErrorCode = 0
     Authentication:Full-Username = onboardt2
     Authentication:MacAuth = NotApplicable
     Authentication:NetBIOS-Name = SSAV
     Authentication:OuterMethod = PAP
     Authentication:Posture = Unknown
     Authentication:Source = GP-AD
     Authentication:Status = User
     Authentication:Username = onboardt2
     Authorization:Sources = GP-AD
     Connection:Client-Mac-Address = 00:23:12:55:a0:5f
     Connection:Client-Mac-Address-Colon = 00:23:12:55:a0:5f
     Connection:Client-Mac-Address-Dot = 0023.1255.a05f
     Connection:Client-Mac-Address-Hyphen = 00-23-12-55-a0-5f
     Connection:Client-Mac-Address-NoDelim = 00231255a05f
     Connection:Client-Mac-Vendor = Apple, Inc
     Connection:Dest-IP-Address = 127.0.0.1
     Connection:Dest-Port = 1812
     Connection:NAD-IP-Address = 127.0.0.1
     Connection:Protocol = RADIUS
     Connection:Src-IP-Address = 127.0.0.1
     Connection:Src-Port = 56843
     Connection:SSID = GP-OBSecure
    Input Authorization Attributes -
     Authorization:GP-AD:All Groups = Faculty
     Authorization:GP-AD:memberOf = CN=Faculty,OU=MainUsers,DC=ssav,DC=com
     Authorization:GP-AD:UserDN = CN=onboard t2,OU=MainUsers,DC=ssav,DC=com
    Output RADIUS Attributes -
     Radius:Aruba:Aruba-Mdps-Max-Devices = 1
  • 6.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 02:40 PM
    Just tested this in my lab as well.  Set Aruba-Mdps-Max-Devices = 1 in the Enforcement Profile for iOS onboard authorization service. I was still able to onboard two devices.  Am I missing something...
  • 7.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 05:41 PM
    Do you have insight enabled and is it an authorization source for your service?
  • 8.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 06:47 PM
    I did have Insight enabled however I did not have Insight specified an authorization source. I just set Insight as an authorization source for the iOS onboard authorization service however I was still able to onboard two different devices when the enforcement profile should be limiting me to one...
  • 9.  RE: Onboard Device Limits by Group
    Posted Jun 10, 2013 10:07 PM
    Make sure in your service you enable insight as an authorizeation source and in the enforcement you use that source.
    Here are a few example ones that I use for Guests.
  • 10.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 07:23 AM
    OK, I am confused now.  When you said enable Insight as an authorization source in your service, I enabled the [Insight Repository] as an authorization source.  Your screenshots seem to indicate that you are referring to the [Endpoints Repository] authorization source.
    My best understanding (from talking to TAC and from Colin's post above) is that I should be returning the Aruba:RADIUS attribute Aruba-MDPS-Max-Devices = X  in the Enforcement Profile for my iOS onboard authorization role in order to limit the number of unique devices which a particular user can onboard and give users an error message when they exceed this limit.  This is unfortunately not working for me.  I am hoping this is because I am missing something simple.
    Your examples show a different approach however from the look of it, this would result in users who have exceeded their device allowance getting a plain RADIUS Reject.  This would show up as a username/password failure in the onboard process with no indication to the user what the cause is - correct?
  • 11.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:03 PM
    Endpoint authorization does limit the devices, however, that's not exactly what I was going for. Like Drew says, this showed an Invalid username or password message on the captive portal page when I tried it. Aruba-MDPS-Max-Devices doesn't work for me, either. I would like users to see an onboard device limit exceeded message, or something like that. Is this possible? What could cause Aruba-MDPS-Max-Devices to not work?
  • 12.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:27 PM
    Sorry about that Ive been working on a couple dozen projects.
    So what you want to do is make an enforment policy that will use the max MDPS. Is this what you tried and didnt work?
  • 13.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:41 PM
    Exactly. This isn't working. :(
    Here's the policy:
  • 14.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:42 PM
    How are you assigning the role?
  • 15.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:43 PM
    and what is being shown in the access tracker
  • 16.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:44 PM
  • 17.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 03:46 PM
     Session Identifier: R0000002e-01-51b77e24
     Date and Time: Jun 11, 2013 15:44:36 EDT
     Username: onboardt2
     End-Host Identifier: 28:6a:ba:ea:9c:9f
    Policies Used -
     Service: GPS-PreAuthentication
     Authentication Method: Authorize
     Authentication Source: None
     Authorization Source: [Endpoints Repository], GPS-AD
     Enforcement Profiles: Onboard 1 Device
     Radius:Aruba:Aruba-Essid-Name = GPS-OBSecure
     Radius:IETF:Calling-Station-Id = 28:6a:ba:ea:9c:9f
     Radius:IETF:Connect-Info = 10.0.10.1
     Radius:IETF:Event-Timestamp = 2013-06-11 15:44:36
     Radius:IETF:Framed-IP-Address = 10.0.10.1
     Radius:IETF:Login-IP-Host = 10.0.0.90
     Radius:IETF:NAS-Identifier = gpscp.ssavserver.com
     Authentication:Full-Username-Normalized = onboardt2
     Authentication:OuterMethod = Authorize
     Authentication:Status = None
     Authorization:Sources = [Endpoints Repository], GPS-AD
     Connection:Client-Mac-Address = 28:6a:ba:ea:9c:9f
     Connection:Client-Mac-Address-Colon = 28:6a:ba:ea:9c:9f
     Connection:Client-Mac-Address-Dot = 286a.baea.9c9f
     Connection:Client-Mac-Address-Hyphen = 28-6a-ba-ea-9c-9f
     Connection:Client-Mac-Address-NoDelim = 286abaea9c9f
     Connection:Client-Mac-Vendor = Apple, Inc.
     Connection:Src-Port = 34159
     Connection:SSID = GPS-OBSecure
     Authorization:GPS-AD:All Groups = GHS Faculty
     Authorization:GPS-AD:memberOf = CN=GHS Faculty,OU=MainUsers,DC=ssavserver,DC=com
     Authorization:GPS-AD:UserDN = CN=onboard t2,OU=MainUsers,DC=ssavserver,DC=com
  • 18.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 04:06 PM
    And you said that it does deny the 2 device when you get the install profile on the device or is it just letting it on.
  • 19.  RE: Onboard Device Limits by Group
    Posted Jun 11, 2013 04:32 PM
    I was able to onboard a second device without issue, last night. Right now though, I am getting profile invalid errors on other devices I'm trying to onboard with the same user name, even after clearing the onboard repository and deleting the client certificate. I'm not sure what the problem is. Seems like a separate issue. I know for a fact that I have successfully onboarded three devices even with mdps max set to 1.
  • 20.  RE: Onboard Device Limits by Group
    Posted Jun 12, 2013 09:15 AM
    Further testing shows that the Mdps-Max-Devices attribute DOES work as expected for both Android and Windows devices.  These platforms both have native onboarding apps.  Apple devices however rely on a web page for onboard authorization before going into the over-the-air provisioning process.  It appears that this web page is not abiding the Mdps-Max-Devices attribute.
    I am at a loss trying to think of what else we can change in the configuration to make this work.  Are any other users encountering this issue with ClearPass 6.1.X?
  • 21.  RE: Onboard Device Limits by Group
    Posted Jun 12, 2013 11:16 AM
    I am having exactly the same issue.
  • 22.  RE: Onboard Device Limits by Group
    Posted Jul 02, 2013 06:27 AM
    ever got further on this, or does it remain an issue?
  • 23.  RE: Onboard Device Limits by Group
    Posted Jul 03, 2013 02:01 PM
    We did get to the bottom of it eventually.  Part of the problem was that we did not realize (because it was not documented anywhere) that the "Invalid Profile" message iOS devices were receiving was not some weird bug, but the result of the mdps-max-devices attribute being applied.  Apparently due to the constraints of the iOS over-the-air provisioning method, ClearPass could not return a sane error message indicating that a user had already onboarded their maximum allowed devices.  Instead, it just sends out a bogus provisioning profile and leaves the user scratching their head as to why things went wrong.
    This problem was combined with the other issue that we ran into which is that ClearPass was treating usernames as case sensitive during the onboard authorization process.  This resulted in users being able to exceed the max devices limit by changing the case of any letters in their user names (e.g. - tom, Tom, and toM were all being treated as different users).  iOS has a tendency to capitalize the first letter of usernames...
    I am glad to say that these issues have been (mostly) resolved in the 6.1.2 patch release.  There is now a check box to disregard case-sensitivity in usernames and now an explanatory error message is displayed after the "invalid profile" message during iOS onboarding if users are smart enough to switch back to the web browser to see it.
    Anyway, thanks for the assistance in this everyone!
