Onboard device restriction with exception
  • 1.  Onboard device restriction with exception
    Posted Aug 29, 2018 03:43 AM
    Hi
    Customer want to restrict all employee onboarded device count max 3, but they also want to extend this policy for vip users like 5
    I configured onboard provisioning settings max device as 5, I created a rule like authorization:endpoint_repository unique device count greater than 3 and authorization groups not equals vipusers [deny application access profile] I used this rule at application service, I tested but still users can onboard more than 3 device
    How can I create and use exceptional onboard device rules?
  • 2.  RE: Onboard device restriction with exception
    Posted Aug 29, 2018 07:51 AM
    Exceptions should be done based on users, not devices.
  • 3.  RE: Onboard device restriction with exception
    Posted Aug 29, 2018 02:43 PM
    You could also try applying the the below Max device limit enforcement for the employees in the OnBoard Authorization(application) service. This would restrict the non VIPs provisioning limit.
    E.g:
     "Authorization:AD Groups Not Equals VIP" apply OnBoard Device limit.
  • 4.  RE: Onboard device restriction with exception
    Posted Aug 31, 2018 03:38 AM
    Thank you Saravanan It worked :)
  • 5.  RE: Onboard device restriction with exception
    Posted Aug 30, 2018 02:56 AM
    We created 2 provisioning profiles, one containing the 3 limit (standard) and one containing the 5 limit (VIP). All other settings were the same.
    In the Onboard pre-auth application service, we created an authorisation check that matched a valid VIP AD group and that resulted in the VIP provisioning profile being assigned therefore allowing more devices. All other users got the standard profile.
