Onboard Fail to Redirect After Client IP Address Change.
  • 1.  Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 25, 2018 01:57 PM
    My Onboarding (two SSID's) is working until the IP address of Onboarding client changes.    No IP address change for the ClearPass, I can still put in Onboard client browser for https://MyClearpass/guest.onboard.php and it will continue to Onboard, but client won’t redirect when open browser to say http://1.1.1.1
    • Cache and history of the browser has been clear.
    • Onboard whitelist is including ClearPass IP address
    • DNS is working
    • Onboarding licenses are available
    • Move the client back to previous IP address, it will work
    Does it configure somewhere in the Onboard process for a network to allow to redirect?  Aruba OS 6.5, CPPM 6.6.8
    Best Regards,
  • 2.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 25, 2018 02:20 PM
    Edit: Misread your question
  • 3.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 25, 2018 02:59 PM
    Why would the device's IP address change?
  • 4.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 25, 2018 03:08 PM
    Forgot to mention: IP address change to a new subnet because the network reconstruction.
    The redirect pause is 3 seconds
    Not sure about CoA/Client bounce.  The process is client connect to "onboard", CPPM steers client to "onboard-login" role with captive portal
  • 5.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 25, 2018 03:26 PM
    Captive portal profile (change redirect to default 10 sec and to allow http)
    (WC03) #show aaa authentication captive-portal Onboard2
    Captive Portal Authentication Profile "Onboard2"
    Parameter                                          Value
    Default Role                                       guest
    Default Guest Role                                 guest
    Server Group                                       CLEARPASS
    Redirect Pause                                     10 sec
    User Login                                         Enabled
    Guest Login                                        Disabled
    Logout popup window                                Enabled
    Use HTTP for authentication                        Enabled
    Logon wait minimum wait                            5 sec
    Logon wait maximum wait                            10 sec
    logon wait CPU utilization threshold               60 %
    Max Authentication failures                        0
    Show FQDN                                          Disabled
    Authentication Protocol                            PAP
    Login page                                         http://1.2.3.4/guest/onboard2.php
    Welcome page                                       /auth/welcome.html
    Show Welcome Page                                  No
    Add switch IP address in the redirection URL       Disabled
    Adding user vlan in redirection URL                Disabled
    Add a controller interface in the redirection URL  N/A
    Allow only one active user session                 Disabled
    White List                                         ONBOARD-WHITELIST
    Black List                                         N/A
    Show the acceptable use policy page                Disabled
    User idle timeout                                  N/A
    Redirect URL                                       N/A
    Bypass Apple Captive Network Assistant             Disabled
    URL Hash Key                                       N/A
  • 6.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 26, 2018 04:38 AM
    Just to be clear, you mentioned 2 SSID onboarding. The IP change you are reporting is that between the two SSIDs, or is it on the same SSID?
    You should try to avoid switching VLAN within a SSID at all cost; your client will not detect that the VLAN has changed and keeps trying with the already assigned IP address that does not have connectivity in that new VLAN.
    Different VLANs between different SSIDs should be fine in most cases.
  • 7.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Jan 26, 2018 09:26 AM
    While I am doing two SSID's onboarding, I use one subnet, so no IP address change.
    Also another point to mention: the working subnet is layer 2 to ClearPass, the problem subnet is layer 3 to ClearPass.
  • 8.  RE: Onboard Fail to Redirect After Client IP Address Change.
    Posted Feb 05, 2018 04:49 PM
    After working with TAC ClearPass engineer and controller engineer, he found my problem is NOT ClearPass, but in the controller.
    For the redirection to work, the new subnet/Vlan interface MUST be configured with an IP address.
    Confirm by ping at the controller with source of the new vlan:
    WC03 #ping 8.8.8.8 source 100
