onboard over vpn
  • 1.  onboard over vpn
    Posted Jul 17, 2015 11:23 AM
    we would like to have our home users onboard their devices over vpn connections. Can this be done and if so, is there any supporting documentation on the work effort?
  • 2.  RE: onboard over vpn
    Posted Jul 19, 2015 03:59 PM
    can you provide some more details?
    like who should set up the VPN? between which devices? isn't https enough? ...
  • 3.  RE: onboard over vpn
    Posted Jul 22, 2015 11:07 AM
    not sure I understand. These are corp users at home using dialing in with VPN. If they do not have the corp cert on the device they need to get routed to onboard their home device (win/mac).
    as for https, are you suggesting they manually go to a captive portal to onboard once connected to the vpn?
  • 4.  RE: onboard over vpn
    Posted Jul 22, 2015 11:08 AM
    I don't believe Onboarding is possible via VPN since some attributes are not
    available for the Onboard process.
  • 5.  RE: onboard over vpn
    Posted Jul 22, 2015 11:15 AM
    would their be an type of workaround that you can think of?
  • 6.  RE: onboard over vpn
    Posted Jul 22, 2015 11:17 AM
    You could do web enrollments.
