Onboard provisioning problems - Cannot send HTTP Request - 12175
  • 1.  Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 07:02 AM
    Hi Community,
    I´ve a problem with my onboard configuration, I can´t provision to my clearpass,
    when I test the provisioning with a windows 7 client the log shows this message:
    we use CPPM 6.2.0
    I put the log as attachment....
    Have anyone an idea?
    Attachment(s)
    txt
    quick1x.txt   28 KB 1 version
  • 2.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 07:32 AM
    It looks like the Windows client cannot trust the server certificate.
    Do this:
    To confirm this is a certificate issue, navigate to Home » Onboard + WorkSpace » Deployment and Provisioning » Provisioning Settings and disable Validate Certificate option.  Also in this configuration section, make sure you have the provisioning address set to the FQDN.
  • 3.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 08:45 AM
    OK, thanks that works...
    but now I´ve another Problem.
    I put the log file into the attachment.
    Maybe you or anybode else have an idea how to fix this.
    Attachment(s)
    txt
    error.txt   63 KB 1 version
  • 4.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 08:49 AM
    Is this after you click on "Finish"?
  • 5.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 08:51 AM
    this is after i click connect!
  • 6.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 08:57 AM
    Okay.  Let's work backwards:
    It looks like your initial  redirect to onboard is http://192.168.88.225...  Can you redirect it to https://fqdn on certificate, instead.
  • 7.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 09:09 AM
    Ok where can I change this?
  • 8.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 09:29 AM
    Leon123,
    You might want to open a case. There are a few things that you would need to get checked, like that your clients trust your server's CA and that your provisioning URL points to the server's fqdn . checking those would be painful on a forum and we would only be troubleshooting symptoms. Please open a TAC case.
  • 9.  RE: Onboard provisioning problems - Cannot send HTTP Request - 12175
    Posted Sep 03, 2013 09:31 AM
    OK thanks.
