Onboard - TLS Issues, User not found
  • 1.  Onboard - TLS Issues, User not found
    Posted May 30, 2017 02:02 AM
    Clearpass VA (ESXi) with Onboarding version 6.6.5.93747
    so trying to setup onboarding using a single SSID..
    I have used the wizard to create the necessary services and policies.
    I have then created the necessary networks, CA Server and onboarding profiles.
    I have modified the pre-provisioning Enforcement profile to allow me to authenticate to AD for the PEAP portion of the process.
    I have then tested this with a windows 10 machine, the peap works fine and i can get to the onboarding page and download the software. I can run the software and get a Certificate installed (under the user's Certificate store) and the computer gets configured to then connect using TLS.
    But the TLS Authentication fails with the error message
    Error Code: 201
    Error Category: Authentication failure
    Error Message: User not found
     Alerts for this Request
    RADIUS
    [Onboard Devices Repository] - localhost: User not found.
    [Guest User Repository] - localhost: User not found.
    EAP-TLS: Authentication failure, unknown user
    I have looked under onboard and the user is registered and the device is registered as well..
    What am i missing...
  • 2.  RE: Onboard - TLS Issues, User not found
    Posted Jun 09, 2017 08:39 PM
    Make sure your identity store is added as an authentication source.
    Also, dual SSID onboarding is recommended in most cases.
  • 3.  RE: Onboard - TLS Issues, User not found
    Posted Oct 10, 2017 08:24 AM
    I´ve got this exact issue, did you manage to solve it ?
  • 4.  RE: Onboard - TLS Issues, User not found
    Posted Oct 10, 2017 09:56 AM
    Anyone got any tips ?
    My computer I´m testing with doesn´t get connected. Access tracker shows errorcod 201 "User not found"
    But I managed to onboard a iphone. Problem is auth. source showes Active Directory instead of Onboard database.
    Service has auth sources: onboard database, active directory, and a mac-list (in that order)
    Very strange...
  • 5.  RE: Onboard - TLS Issues, User not found
    Posted Oct 10, 2017 10:51 AM
    ok, so I managed to get my computer to work also by adding user name strip :/
    But auth source in access tracker showes AD as source...
    But if I revoke the cert i get denied. So is this how it should be by design ? I thought onboard database would show as source.
    How does your access tracker look for onboarded devices ?
    Am I missing something ?
  • 6.  RE: Onboard - TLS Issues, User not found
    Posted Oct 10, 2017 08:06 PM
    The only authentication source that should be defined would be your identity store (Active Directory).
  • 7.  RE: Onboard - TLS Issues, User not found
    Posted Oct 11, 2017 02:34 AM
    Ok, so devices are actually not authenticated against the onboard database. The certificate is the mechanism controlling the access for them ?
    So should I need to strip /:user to actually make this work ? Can´t remember having this in there before and it has worked before.
  • 8.  RE: Onboard - TLS Issues, User not found
    Posted Oct 11, 2017 07:32 AM
    All the certificate does it replace the user password. The user is still authorized against the identity store.
  • 9.  RE: Onboard - TLS Issues, User not found
    Posted Oct 11, 2017 08:04 AM
    Great thanks, now I understand the proccess better.
  • 10.  RE: Onboard - TLS Issues, User not found
    Posted Oct 31, 2018 08:48 AM
    Hi
    So what should be correct Authentication Sources for 802.1x wired access for computers added with OnBoard? Having only Onboard Devices Repository ends with: " Alerts for this Request
    RADIUS [Onboard Devices Repository] - localhost: User not found.
    EAP-TLS: Authentication failure, unknown user"
    I would like to accomplished the screnerio where I deliver only machine certificate and the computer authorizes before the user login.
  • 11.  RE: Onboard - TLS Issues, User not found
    Posted Oct 31, 2018 08:53 AM
    No auth source.
  • 12.  RE: Onboard - TLS Issues, User not found
    Posted Oct 31, 2018 05:02 PM
    The auth source is set to Onboard device repository.
    Should I add another one?
  • 13.  RE: Onboard - TLS Issues, User not found
    Posted Oct 31, 2018 05:27 PM
    No, you shouldn's have any auth sources if you're not using user credentials.
