Onboard TLS Session Error
  • 1.  Onboard TLS Session Error
    Posted May 07, 2014 08:29 AM
    Dear All,
    I had provision my Android Devices successfully in CPPM 6.3.
    But tried to connect WiFi with 802.1X EAP-TLS. It always failed.
    When I checked CPPM Access Tracker below:
    And I also checked my Certification chain below:
    In CPPM, I could find my devices below:
    Anyone help me to solve this issue?
    BR
    Thanks a lot.
  • 2.  RE: Onboard TLS Session Error
    Posted May 07, 2014 09:10 AM
    A couple of things :
    - Make sure you have TLS enabled under the  802.1x
    - Do you have the trus sett to  automatically or manually ?
    - Are you using OCSP ?
  • 3.  RE: Onboard TLS Session Error
    Posted May 07, 2014 09:20 AM
    you appear to have two root CAs in your chain, is that on purpose?
    i would check if your client does actually send the correct certificate.
  • 4.  RE: Onboard TLS Session Error
    Posted May 07, 2014 09:31 AM
    Dear boneyard,
    I checked only one Root CA in CPPM.
    any idea?
  • 5.  RE: Onboard TLS Session Error
    Posted May 07, 2014 09:41 AM
    you are now mixing things, at "And I also checked my Certification chain below:" you show a chain with a double root CA. not sure if that might cause issues.
    for the rest i would take a step back, what does work? start with something simple, only username / password. move to your own certificates and then perhaps move to onboarding and check it is setup following guides. it is difficult to understand your full setup based on a few screenshots.
    if you have support call TAC, they can go through your whole setup more easily.
  • 6.  RE: Onboard TLS Session Error
    Posted May 07, 2014 09:23 AM
    Yes! And Automatic trust certificate!
    Please see below:
  • 7.  RE: Onboard TLS Session Error
    Posted May 07, 2014 06:36 PM
     If you edit ocsp authentication method it should match the URL in the Onboard settings
  • 8.  RE: Onboard TLS Session Error
    Posted Jul 22, 2015 05:09 AM
    Hi Victor Fabian,
    wehre can I find the "Certificate Authority Settings" on the GUI to copy the OCSP URL?
    thx
    Markus
