Onboard Wizard - QuickConnect encountered an error condition
  • 1.  Onboard Wizard - QuickConnect encountered an error condition
    Posted Jul 18, 2016 12:57 AM
    In an environment that previously had ClearPass Onboard working with ADCS integration - I'm hitting an error when running the QuickConnect app on Windows 7 and 10 machines (haven't tried mobiles or anything else).
    Logs attached. It looks like the client may not be generating its private key properly, although there is also an HTTP error 500 by the looks of things:
    2016-07-18 16:46:27,458 [null] DEBUG Quick1X.ParseMobileConfig - Retrieving value of Validate-Server-Certificate option
    2016-07-18 16:46:27,458 [null] DEBUG Quick1X.ParseMobileConfig - Disabling Onboard server certificate validation
    2016-07-18 16:46:27,614 [null] DEBUG Quick1X.ParseMobileConfig - HTTP Status Code500
    2016-07-18 16:46:27,880 [null] DEBUG Quick1X.ParseMobileConfig - The type of networkconfig
    2016-07-18 16:46:27,880 [null] ERROR Quick1X.QuickConnectDlg - Could not parse mobileconfig file
    To confirm I don't have a device limit configured.
    Only thing I can think of is this being an issue introduced after upgrading to 6.6...
    Has anyone seen any issues like this before?
    Attachment(s)
    txt
    logs.txt   33 KB 1 version
  • 2.  RE: Onboard Wizard - QuickConnect encountered an error condition
    Posted Jul 19, 2016 12:38 AM
    Turned out to be ClearPass system wide proxy settings...
    ADCS requires NTLM authentication which doesn't play nice through a proxy.
    Remove proxy settings and viola :)
  • 3.  RE: Onboard Wizard - QuickConnect encountered an error condition
    Posted Jul 25, 2018 11:40 AM
    you say it was a clearpass system wide proxy setting.... which setting are you referring to? I believe I'm seeing the same error, but don't believe I have any proxies turned on.
