Onboarding for Linux
  • 1.  Onboarding for Linux
    Posted Mar 13, 2014 07:02 AM
    i'm trying to get some info about onboarding for Linux. is there any plan or testing going on for this?
    R.L.
  • 2.  RE: Onboarding for Linux
    Posted Mar 13, 2014 08:04 AM
    "Onboarding" is a process where certificates or credentials are automatically provided to a client and the  secure WLAN is configured with those credentials or certificates.  You can certainly generate a unique client certificate for that LInux box and configure the WLAN manually.
  • 3.  RE: Onboarding for Linux
    Posted Mar 14, 2014 04:42 AM
    hi Colin,
    what do you mean manually? i dont see linux configuration in the onboard configuration for quickconnect. does Aruba has a quickconnect apps for Linux? well, i'm trying to set up one for testing. do you have a list of linux distribution that have been tested and working for onboarding?
    R.L.
  • 4.  RE: Onboarding for Linux
    Posted Mar 17, 2014 06:48 AM
    rickylee,
    The different flavors of Linux do not have an API to generate and distribute certificates like the other operating systems.  I wrote a tutorial on how to do it through the ClearPass Onboard CA here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/TUTORIAL-How-to-generate-TLS-certificates-for-Linux-using-the/m-p/149236
  • 5.  RE: Onboarding for Linux
    Posted Mar 17, 2014 10:14 PM
    Hi Colin,
    thanks for the great tutorial. i was assuming that we can do it via quickconnect so user do not have to manually export import a cert.
    does using the cert from clearpass CA even without quickconnect takes a slot from enterprise license?
    R.L.
  • 6.  RE: Onboarding for Linux
    Posted Mar 17, 2014 10:23 PM
    @rickylee wrote:
    Hi Colin,
    R.L.
    There is no Quickconnect support for Linux.  An issued certificate that is not revoked or expired consumes an Onboard or Enterprise license.
  • 7.  RE: Onboarding for Linux
    Posted Aug 11, 2014 12:32 PM
    We have tried the tutorial provided and were unable to connect Linux devices.  I was hoping that someone on this forum had success.  We received the following error from Clearpass when the user tried to connect:
    RADIUSEAP: Client doesn't support configured EAP methods
    We also were a little unclear as to what went into the Identity section when manually creating the connection.  Is it the Username?
    Thanks for any help you can provide.
  • 8.  RE: Onboarding for Linux
    Posted Aug 11, 2014 12:52 PM
    bpierce815,
    The article assumes that you already have Onboarding configured for other devices like Mac and Windows.  The error in your post is when you do not have EAP-TLS in your authentication methods.
  • 9.  RE: Onboarding for Linux
    Posted Aug 11, 2014 02:30 PM
    I have solved my own problem.  In the NetworkManager configuration, you must leave off the CA certificate as linux refuses to validate a self-signed cert.
  • 10.  RE: Onboarding for Linux
    Posted Aug 11, 2014 02:42 PM
    Kudos for solving your own issue!
