Onboarding in a global cluster?
  • 1.  Onboarding in a global cluster?
    Posted Mar 05, 2017 07:10 PM
    Hi Forum,
    To simplify it (for myself of course), I have 3 CP 5k (one in each global region) with a publisher in the US. I configured onboarding and it is working fine. My question is:
    Under Onboard>>Configuration>>Network Settings>>edit>>trust tab>>Configure trust:
    If I set it to manually configure certificate trust settings, which CP's cert should I add here(from the dropdown)? I understand this cert will be installed on enduser root certs store.
    Should it be the publisher's cert or should I add all 4 CP's here? if so, what should I do if I have 10 CPs instead of 4!!
    Thanks in advance.
  • 2.  RE: Onboarding in a global cluster?
    Posted Mar 05, 2017 07:12 PM
    It's recommended to use a single RADIUS/EAP server certificate in a cluster. Is that the case in your environment?
  • 3.  RE: Onboarding in a global cluster?
    Posted Mar 05, 2017 07:18 PM
    Thanks for the response Tim!
    Each node has it's own Radius cert issued by the root CA (MS PKI).
  • 4.  RE: Onboarding in a global cluster?
    Posted Mar 05, 2017 07:22 PM
    You should use the auto trust config then.
  • 5.  RE: Onboarding in a global cluster?
    Posted Mar 05, 2017 07:24 PM
    I've noticed with auto trust, iOS devices fail to install the profile.
  • 6.  RE: Onboarding in a global cluster?
    Posted Mar 05, 2017 07:26 PM
    Did you do step 1 during onboarding which installs your root CA?
