Onboarding on android problem ?
  • 1.  Onboarding on android problem ?
    Posted Aug 14, 2015 03:18 PM
    I have configured onboard service and all is well teh issue is quick connect stuck in Checking connectivty and keep tring to connect to the Secure SSID and when I check access track I found that it Say EAp method not support by client and it is support by the Device and attached the Access tracker
  • 2.  RE: Onboarding on android problem ?
    Posted Aug 14, 2015 03:20 PM
    What kind of device is it?
    What firmware is it running?
    Can you manually connect at the system level?
    Tim
  • 3.  RE: Onboarding on android problem ?
    Posted Aug 14, 2015 03:58 PM
    Samsung Note-2     android Kitkat
  • 4.  RE: Onboarding on android problem ?
    Posted Aug 14, 2015 04:08 PM
    There are know issues with the 802.1X supplicant on the Note 2. You may want to stick with PEAP.
  • 5.  RE: Onboarding on android problem ?
    Posted Aug 14, 2015 06:36 PM
    Dear Tim thank you so much I tried with Samsung S4 worked like charm no problem at all :) thank you Expert :)
